12-08-2006, 11:08 | #1 (permalink) |
Freak Poster Join Date: Jun 2004
Member: 68795 Status: Offline Thanks Meter: 0 | E1070 not unlocked after tespoint unlock ?? Anyone know whats wrong ? |
12-08-2006, 11:12 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Itsbroke, please tell us what Smart-Clip and SmartMoto versions you use. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-08-2006, 11:57 | #3 (permalink) |
No Life Poster Join Date: Sep 2005 Location: UK, London Age: 35
Member: 177235 Status: Offline Sonork: 111568 Thanks Meter: 138 | Hi, There are new version of E1070, So far i know only on the network 3. It seems this version is like the C975 91i.... version which is still locked after unlock. We can try to flash it with latest firmware then unlock, But pls firstly read flash and send it to support. B.R |
12-08-2006, 13:26 | #5 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Itsbroke, Please show log file, don't forget to hide seial number. Also,please specify what boot and firmware versions the phone has and tell us what OS you are using. Thank You! Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-08-2006, 17:01 | #6 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | e1070 boot loader 0.6.8.1 sw version R252211LD_U_.97.F11P Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: xxxxxxxxxxxxxx Security area saved to "S Blank Rainbow POG xxxxxxxxxxxx(1).pds" Unlocking phone... OK Turning phone off... OK BUT THE PHONE STILL LOCKED Searching for phone... found Motorola Phone (E1070), getting test interface... OK Model E1070 Firmware R252211LD_U_85.97.F11P Reading info OK as we know that we had no solution for C975 with sw ending with 91i so here goes another model in the same list REASON FOR POSTING IS TO HELP OTHERS TO WAIST THEIRE TIME FOR DRILLING AND UNLOCKING ETC BR |
12-08-2006, 17:45 | #7 (permalink) |
Member: 68795 Status: Offline Thanks Meter: 0 | Need back up flash of 3 E1070 Hi I have really screwed this up !! I tried to unlock an E1070 on 3 UK, it said done OK but it wasn't unlocked, tried to do PDS repair, then flash full flash from support but now wont power on just flash keypad, but will go into boot mode with *# power pressed, I need a full backup of this handset as the one in support doesn't work I have seen posts from others who have reflashed with back up from an identical handset then restored the original security area and handset alive again, I just desperately need the back up flash file for this |
12-08-2006, 23:43 | #8 (permalink) |
Member: 177235 Status: Offline Sonork: 111568 Thanks Meter: 138 | Well like i posted above it has a very similar patched firmware like on the c975 91... version. Try to flash the fone using upper version or the same. B.R |
12-09-2006, 01:16 | #9 (permalink) | |
Member: 91102 Status: Offline Thanks Meter: 34 | Quote:
u can't flash backup made by one smart-clip with another smart-clip c if u can find this file in support area R252211LD_U_.97.F11P br | |
12-09-2006, 10:57 | #10 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | That version can be unlocked with the latest version of SmartMoto (with use of Smart-Clip and S-Card), which has a "firmware version check" process implemented. While connecting the handset to SmartMoto and trying to unlock, if the software does not alert you: "In case of downgrading the firmware version the handset might not turn ON", then flash it with the lower full_flash version and perform "Unlock via TestPoint". Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-22-2007, 13:54 | #12 (permalink) |
Insane Poster Join Date: May 2005 Age: 47
Member: 144041 Status: Offline Thanks Meter: 1 | strange problem motorola E1070 i have i strange problem motorola E1070 i did same ,I unlocked an E1070 via testpoint, ubl says unlocked ok but phone still asking for subsidy password ???? i pressed repair bt and i get terminal blocked Anyone know whats wrong ? |
03-22-2007, 14:05 | #13 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: Scotland, UK. Age: 43
Member: 83741 Status: Offline Sonork: 100.1624702 Thanks Meter: 88 | Quote:
WBR MFC | |
03-23-2007, 16:26 | #14 (permalink) |
Member: 144041 Status: Offline Thanks Meter: 1 | if you know what its wrong why you dont just give answer , just here we are learning and sharing information ok? thanx for any one guid and shar information NO ONE CAN DO EVERY THINGS BUT ANY ONE CAN DO SOME THING . |
03-23-2007, 18:58 | #15 (permalink) | |
WBR MFC | |
K1/S not unlock after successful UNLOCK | zakiyyboss | Smart-Clip | 1 | 01-20-2009 14:24 |
E65 loudspeaker not working after TP unlock | donish | Nokia Hardware & Hardware Repair | 3 | 03-04-2008 22:20 |
T610 not working after bad unlock | Delsole | Sony Ericsson | 1 | 02-17-2006 09:08 |
Modem not working after e616v unlock | pucuchu | NEC | 0 | 03-25-2005 06:40 |
M55 not charging after testpoint unlock | DMD | E-Gold Based Phones | 1 | 12-09-2004 11:25 |
