01-26-2007, 19:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 224919 Status: Offline Thanks Meter: 3 | Error flashing a925 need Smf firmware This is my log when I tru to flash It Code: Grazie a Dengel <[email protected]> per la traduzione in Italiano! SmartMoto 1.23 Seriale della clip: 1178xxxxx, versione: 2.26, Inizializzazione in corso... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F640W18B (x2) Phone group: A835,A845,A920,A925 Hardware IMEI: 352745000597660 Security area saved to "S Blank Rainbow POG 352745000597660 (2).pds" Writing security area... done "S Blank Rainbow POG 352745000597660.smb" saved, 16 Mb Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found Blank A920 Paragon, getting test interface... interface not found Switching to flash mode... OK [S Blank Rainbow POG] Searching for phone... found Blank A920 Paragon, getting test interface... reconnect error Searching for phone... found Motorola P2K, getting test interface... interface not found Unable to connect to the Subscriber Unit. Unable to retrieve interface handle Searching for phone... found Motorola P2K, getting test interface... interface not found Operation log saved to "\\Home\d\SmartMoto log 26-01-2007.3txt" Searching for phone... found Motorola P2K, getting test interface... interface not found Searching for phone... found Motorola P2K, getting test interface... interface not found Error Processing Flash File Error Processing Flash File Error Processing Flash File Error Processing Flash File Verify failed Error Processing Flash File Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Unable to connect to the Subscriber Unit. Unable to retrieve interface handle Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Unable to connect to the Subscriber Unit. Unable to retrieve interface handle Creating image file Loading RAM downloader for Bootloader Error sending RAM download for bootloader. Error 0xE0030008 while sending address 0x1009A000. Loading AP RAM-downloader failed Phone is powered down Searching for phone... found Motorola P2K, getting test interface... interface not found Error Powering Down Subscriber Unit. Error 0xE0030008 Power down SU FAILED!!! Flash failed Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Unable to connect to the Subscriber Unit. Unable to retrieve interface handle Searching for phone... found Motorola P2K, getting test interface... interface not found Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Unable to connect to the Subscriber Unit. Unable to retrieve interface handle Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Unable to connect to the Subscriber Unit. Unable to retrieve interface handle Creating image file ERROR: phone not compatible with multi-interface super-file Phone is powered down Refreshing device connections Flash failed Creating image file Loading RAM downloader for Bootloader Waiting for re-enumeration The "Motorola_Paragon_OS" Interface could not be found. Phone is powered down Refreshing device connections Flash failed Unable to connect to the Subscriber Unit. Unable to retrieve interface handle Code: Sto cercando il telefono... Trovato Motorola P2K, Sto ottenedo interfaccia test... Interfaccia non trovata Creating image file ERROR: phone not compatible with multi-interface super-file Il telefono è spento Aggiornamento connessione con il telefono Flash fallito Impossibile collegarsi al telefono. Impossibile caricare l'interfaccia Creating image file Loading RAM downloader for Bootloader Waiting for re-enumeration The "Secure_Motorola_Flash" Interface could not be found. The super-file is secure and for re-flash; the phone needs a super-file that is not secure and for reflash. The "Motorola_Paragon_Filesystem" Interface could not be found. Interface AP-OS: Erasing flash memory. Interface AP-OS: Error Erasing Subscriber Unit. Error 0xE0020085 AP-OS Failed Code: 02:45:37, January 26, 2007 Line: 3302 ERROR: Phone[0000]: Unable to retrieve interface handle. File: X:\test_dev_usb\flash\code\flashdll\PST_FP_FlashThread.cpp 02:45:37, January 26, 2007 Line: 326 ERROR: Detailed Error Details for Device ID=0::Error Number=27::Direction of the Error=0::Command Value=4100000::Code Group Number=-256::Error Message=Unable to retrieve interface handle. File: X:\test_dev_usb\flash\code\flashdll\FlashHdlr.cpp 02:57:17, January 26, 2007 Line: 5786 ERROR: Phone[0000]: The "Secure_Motorola_Flash" Interface could not be found. The super-file is secure and for re-flash; the phone needs a super-file that is not secure and for reflash. File: X:\test_dev_usb\flash\code\flashdll\PST_FP_FlashThread.cpp 02:57:28, January 26, 2007 Line: 5786 ERROR: Phone[0000]: The "Motorola_Paragon_Filesystem" Interface could not be found. File: X:\test_dev_usb\flash\code\flashdll\PST_FP_FlashThread.cpp 02:57:28, January 26, 2007 Line: 2925 ERROR: Interface AP-OS: Error erasing subscriber unit. Device API Error: 0xE0020085 Command: ERASE File: X:\test_dev_usb\flash\code\flashdll\PST_FP_FlashThread.cpp 02:57:28, January 26, 2007 Line: 3701 ERROR: Phone[0000]: Flash failed. File: X:\test_dev_usb\flash\code\flashdll\PST_FP_FlashThread.cpp 02:57:28, January 26, 2007 Line: 326 ERROR: Detailed Error Details for Device ID=0::Error Number=66::Direction of the Error=0::Command Value=0::Code Group Number=255::Error Message=The "Secure_Motorola_Flash" Interface could not be found. The super-file is secure and for re-flash; the phone needs a super-file that is not secure and for reflash. File: X:\test_dev_usb\flash\code\flashdll\FlashHdlr.cpp Code: A925_AP_30.11.00_BP_21.32.00 REL_30.80.15_SE8108AC3W8_000_BP.shx REL_35.80.61_full_SHX Code: The "Secure_Motorola_Flash" Interface could not be found. The super-file is secure and for re-flash; the phone needs a super-file that is not secure and for reflash. Can you help me? Thanks a lot BR |
02-01-2007, 23:54 | #3 (permalink) |
Member: 224919 Status: Offline Thanks Meter: 3 | Upgrade: I have update my smartclip with scard to the last version , downloaded a925's pcf files , and try to write in it....Now my telephone have white screen and the Pc and the smartclip don't find it , if i press bottons for boot mode too... the pc says unkown devices... How i can do? I think that i need of a image of A925's tp and or a firmware for smartclip with boot inside , or of a boot file that i flash with tp! Thanks a lot BR |
02-02-2007, 11:31 | #5 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | You can try to flash your A925 with this backup file (restore the backup): Quote:
I have found testpoint for A925 here. Please, take a look there. Last edited by mcandre; 02-02-2007 at 11:44. | |
02-02-2007, 16:26 | #6 (permalink) | |
Member: 224919 Status: Offline Thanks Meter: 3 | Quote:
@mcandre Thanks for the link , but isn't so clear for me the sequence: There is 1.8 V , and other things that i don't understand. Do you have a boot flah or a complete flash with boot inside? Thanks a lot! | |
02-02-2007, 21:18 | #7 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | I have just found similar thread, that is regarding your problem: http://forum.gsmhosting.com/vbb/show...A925+testpoint I hope it can help you to revive your A925... |
need spacial firmware for U890. who can upload? | Maiwand khan | FuriousGold | 1 | 03-29-2010 15:28 |
v3re smf flash file need | khalilahmad | Motorola P2k | 0 | 01-15-2010 19:04 |
I am x7 new flash chip need french firmware | msdgsm | SMTi | 0 | 01-17-2008 23:55 |
V235 flash file needed in .smf smart clip | derk | Motorola P2k | 5 | 01-09-2007 22:39 |
V3x Smf Flash File Needed | lushuai | Smart-Clip | 1 | 08-21-2006 10:21 |
