03-19-2009, 11:19 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2007 Location: In the web Age: 37
Member: 622382 Status: Offline Thanks Meter: 201 | expart plz help me L71 always bootlodear mode Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M30L0R8000T0, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: xxxxxxxxxxx IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 xxxxxxxxx(1).mbk" Login request... OK Writing flash section 2 of 2... 100% (41.2 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (15 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (57.4 Kb/sec) Flash completed! this set always bootlader mode i fullfalsh but problem not solved plz help me.thanks in advanecd |
03-19-2009, 11:25 | #2 (permalink) |
Member: 622382 Status: Offline Thanks Meter: 201 | but when i put battry show this massage Err: PH_VER and go to bootloader mode always bott laoder mode plz help me thanks in adaneced |
03-20-2009, 08:52 | #6 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Do you know what has initially happened to this phone? There is a possibility that in was flashed with wrong firmware. Then restoring IMEI via patch may help. Perform Repair PDS, full flash and right after flashing apply IMEI patch (don't turn off or disconnect phone between these steps). The handset should turn ON. If it does, restore original number using Write button. Best Regards GSMServer team |
03-20-2009, 09:19 | #7 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | What model do you have exactly and what flash files have you used for flashing? Are you sure that you have L71? If yes then flash this phone via Scout using this fw version: pcf\L7i_L7e\R452D_G_08.04.05R |
03-22-2009, 08:08 | #9 (permalink) | |
Member: 622382 Status: Offline Thanks Meter: 201 | Quote:
03-23-2009, 10:13 | #10 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Glad to know that you could fix your phone. Thanks for letting us know. Good luck and take care. Best Regards GSMServer team |
hi plz help me im new | abi.m | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-30-2010 06:43 |
plz help me | lloydgsm | FuriousGold | 3 | 03-29-2010 20:08 |
plz help me its urgent | lloydgsm | SETool2 | 2 | 03-29-2010 17:45 |
plz help me | lloydgsm | SETool2 | 6 | 03-29-2010 13:10 |
dear cdma expart pls help me | rangan_kumar | Various CDMA/TDMA Cell Phones | 2 | 09-23-2009 08:36 |
