F3 unlock error ... Sending boot...0xA007 failed /////////////////////////////////////////////// |
SmartMoto 3.00 S-Card: ******** Smart-Clip dongle, v 2.00, assigned Smart-Clip: ****** Europe, initializing... OK Waiting for the phone to power on...OK Sending boot...0xA007 failed I am using F3 USB cable from GSM server on-line, choose correct port, get the above error ! Can any one advise .... Regards |
make repair epprom then unlock it will be ok tested many times BR, Elkawasmy |
@ MohammedSharif, This error usually appears when the cable wasn't connected properly. Reattach the data cable and run unlock procedure once again. http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
CHECK YOUR BATTERY,USE FULLY CHARGE BATTERY OR CHECK YOUR CABLE |
That error appears when using FTDI interface. Use serial inteface and all will be fine. |
@ cubafreak, Please install the latest version of SmartMoto and run unlock procedure once again. http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
