11-15-2006, 21:38 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 53
Member: 103635 Status: Offline Thanks Meter: 86 | flashin v360 without using the phone batteri!! U can flash motorola v360 witout using the phone's batteri. just follow the steps an no need for connecting the phone batteri: 1. disamble phone 2. cut metal-shield (I use a cutter) 3. connect phone to smartmoto (thru smart-clip) 4. connect TP and press search buttom on smartmoto 5. disconnect TP after getting OK 6. select v36x model and press "unlock via testpoint" buttom on smartmoto. that's it. you are done. and as I mentioned no need to use the phone batteri, i did unlock over 20phones without any problem. good luck. and please proffasional's and people with x-number of stars keep yr comments to yr selves!!!!. this thread is to help new people here who did'nt know about this!!!. |
11-15-2006, 21:59 | #2 (permalink) | |
Freak Poster Join Date: Sep 2004 Age: 48
Member: 81575 Status: Offline Thanks Meter: 12 | Quote:
it's true, but not for all motorola v360 ; sometimes we need batterie or pile of 4.5 volt !! thanks! | |
SETOOL:- Patch UNLOCK without Using USB Phone Drivers | TDKI | SETool2 | 51 | 08-31-2009 11:49 |
Unlock W380 without using the USB drives | NADEEM GONDAL | SETool2 | 5 | 08-26-2008 13:00 |
GX17 is there a way to enable the cable connectivity without using the menu? | Burnt Cobba | Sharp | 2 | 08-15-2007 18:46 |
Some Stufs about using the phone without a sum card | Trek | x4x, x5x Flashpatching | 3 | 12-10-2004 11:54 |
Who the **** is RSA Bootprotectin without open the Phone | leosneffe | Cruiser Suite | 15 | 07-13-2004 17:33 |
