11-27-2006, 22:48 | #1 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Flashing V3X...Problems BR Luskao |
11-28-2006, 09:29 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ luskao, This file RAZRV3x_R25221LD_U_85.83.84P_lp0039_full_flash.smf is unbranded. You can try to flash the phone with it. If it won't help, you can try to downgrade boot, make Repair PDS and after that Full Flash the phone. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-02-2006, 17:45 | #9 (permalink) |
No Life Poster Join Date: Mar 2006 Location: lost in a supermarket
Member: 239318 Status: Offline Thanks Meter: 51 | let me undertand, need no brand flahfile for v3x, i have one is sipmly check your pm, explain me how did u flashed this boot, others are minor and all here in these two days had problems |
03-18-2007, 06:51 | #10 (permalink) | |
No Life Poster Join Date: May 2001
Member: 4675 Status: Offline Thanks Meter: 7 | Quote:
03-19-2007, 08:59 | #11 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ eureka8888, 1. To downgrade boot you have to connect the handset via TP and flash it with boot file. 2. Please show log file, don't forget to hide your serial number. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-20-2007, 05:37 | #12 (permalink) |
Member: 4675 Status: Offline Thanks Meter: 7 | sir here its is SmartMoto 2.20 S-Card: xxxxxxxxxx Smart-Clip dongle, v 1.16, assigned Smart-Clip: xxxxxxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxx, version: 3.15, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... AMD - S71WS512NE0 (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 352241013123595 Security area saved to "PDS for S Blank Rainbow POG 352241013123595 (2).mbk" [1] retrying block erase at 0x12200000... clip communication failed Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... AMD - S71WS512NE0 (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 352241013123595 Security area saved to "PDS for S Blank Rainbow POG 352241013123595 (3).mbk" [1] retrying block erase at 0x12200000... clip communication failed Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Clip serial: xxxxxxxxxxxx, version: 3.15, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... AMD - S71WS512NE0 (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 352241013123595 Reading security area... 96% io timeout Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... AMD - S71WS512NE0 (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 352241013123595 Security area saved to "PDS for S Blank Rainbow POG 352241013123595 (4).mbk" Login request... OK Writing flash section 2 of 2... 100% (112 Kb/sec) Restarting phone... OK Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (26.9 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair [1] retrying block erase at 0x12200000... clip communication failed ========================= phone history, no responce and can't get to boot loader mode 1)action taken: repair pds... now boot loader 0.6.8.2 sw ver: r25221LD_U_85.83.84P 2) flash with r25221LD_U_85.83.84P.mfw process stops with screenshot above 3) flash with rsdlite R252211LD_U_85.99.50R_LP0039_DRM0001_JPRU_R25221GE NERIC_03_USRAZRV3XRURXXR2522100A_1FF.shx error in checksum 4) flash with usb smartt P2k R252211LD_U_85.99.50R_LP0039_DRM0001_JPRU_R25221GE NERIC_03_USRAZRV3XRURXXR2522100A_1FF.shx process finished but still keypad light only 5) flash with rsdlite R252211LD_U_85.99.50R_LP0039_DRM0001_JPRU_R25221GE NERIC_03_USRAZRV3XRURXXR2522100A_1FF.shx error in check sum. question what flash file should i flash? |
03-20-2007, 07:57 | #13 (permalink) |
Member: 81703 Status: Offline Thanks Meter: 1,332 | I think that your phone is damaged. Rsd and SmartClip do not allow to continue writting if there is any problem, the other tool that I do not want to menthion tries writting even the phone reject it. Another info showed was the difficulties found to repair PDS in V3x...Not so many attempts are needed BR Luskao |
03-23-2007, 03:58 | #15 (permalink) | |
Major Poster Join Date: Feb 2007
Member: 449391 Status: Offline Thanks Meter: 0 | Quote:
i have the same problem here | |
problem flashing v3x via rsd 3.5 | fatho | Motorola P2k | 2 | 03-19-2007 01:44 |
Problem flashing v3x | steviepab | Motorola P2k | 2 | 02-18-2007 20:15 |
Help needed -V3x problem after flashing using TP | wadalhag | Motorola Hardware Repair | 3 | 10-29-2006 19:51 |
Help needed -V3x problem after flashing using TP | wadalhag | Smart-Clip | 4 | 10-27-2006 14:46 |
Problem flashing V3X bootloader/Flashloader | The Dog | Motorola P2k | 3 | 07-24-2006 19:42 |
