11-28-2006, 19:31 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: UK
Member: 318507 Status: Offline Thanks Meter: 17 | Help to unlock C975 6.36 801 I have successfully unlocked several testpoint Motorolas but cannot get my head round this one: Stripped phone. Cut out screen. Used Fonefunshop Testpoint/ Battery Box. Plugged in Smart Clip. Ran Smartmoto = Phone not found. Re-assembled phone. Connected to Smartmoto etc = Phone not found Discovered that phone is only detected after power button on keypad is used = Phone found ok but not blank. Ran 'Remove RSA' = Failed Removed back from phone. Tried several different procedures while pressing power button, clipping on power leads and testpoint probe with my 4 pairs of arms. Still not unlocked. Please can someone describe step by step instructions. I have tried serveral different combinations of connecting in different orders but no joy. Thanks GT |
11-28-2006, 20:32 | #2 (permalink) |
Freak Poster Join Date: Jul 2004 Location: always trying Age: 52
Member: 73310 Status: Offline Thanks Meter: 3 | cable,tp,make sure u have the correct one,there are 2 similar points,you need to use the left one,aftercable,tp then bat and then search with sc,the rest is easy |
12-02-2006, 21:21 | #4 (permalink) |
Member: 318507 Status: Offline Thanks Meter: 17 | Tried again. Kept getting 'clip connection failed' or similar. Got blank testpoint a couple of times but could not flash. Have given customer phone back still locked. Any advice please???? |
12-05-2006, 10:20 | #6 (permalink) |
Junior Member Join Date: May 2006
Member: 269390 Status: Offline Thanks Meter: 1 | on phone dracrek on boot lorder C975 6.36 801 smart clip use testpoint Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Micron-MT28F1284W18BET (x2) Phone group: C975,C980,V980 Hardware IMEI: 354991001035205 Security area saved to "S Blank Rainbow POG 354991001035205 (2).pds" Unlocking phone... error 9B |
12-05-2006, 10:22 | #7 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ akhil123, Please make sure that you use standard, not force boot, cable. And try once more. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-05-2006, 15:44 | #8 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: insane in da mad brain Age: 46
Member: 154522 Status: Offline Thanks Meter: 48 | Quote:
12-05-2006, 15:49 | #9 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ freakyass, Try to make Repair PDS and after that Full Flash the handset. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-05-2006, 16:06 | #10 (permalink) | |
12-05-2006, 16:26 | #11 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ freakyass, All files that we have can be found at boot-loader.com If you have S-Card you will see new files, if you don't have it you will have access to old flash files. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-06-2006, 18:05 | #12 (permalink) | |
Member: 154522 Status: Offline Thanks Meter: 48 | thanks man now back to normal and unlocked... Quote:
after wrong unlocking bootloader so the phones become in boot code mode. 1. repair pds with smart clip. 2. change bootloader with 6.1.2 bootloader. 3. flash it with smf file from smart clip ( vodafone one) 4. phone become normal again be careful when removing shield because it can make phones dead, so its solution tested with 80I. regards...... Last edited by freakyass; 12-07-2006 at 09:17. | |
Argent help to unlock c975 | msantar | Smart-Clip | 2 | 02-03-2009 13:27 |
Unlock C975 6.36 80I error 9B | nzeiga | Smart-Clip | 6 | 12-22-2006 15:46 |
Any One Help To Unlock L 6 | LIONMOBILE | Smart-Clip | 1 | 06-07-2006 12:46 |
need help to unlock myx-6 | gorgans | ARM9 BASED M62 / M62+ | 3 | 09-28-2004 15:42 |
help to unlock Myx-6 | MichieMax | Phone Unlocking Codes & Maps | 0 | 11-04-2003 11:17 |
