Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 02-24-2009, 19:35   #1 (permalink)
khurram86's Avatar
Member: 682981
Sonork: 100.1587606
Thanks Meter: 116
Thumbs up w490 unlock done by {T.P}
it 100% works
no signal problem
Searching for phone... found Motorola Phone (W490), getting test interface... OK
Model W490
Firmware R452G_G_08.24.02R
Switching to flash mode... OK [S Flash Neptune LTE2]
Reading phone boot version... C.50
Sending boot... OK
Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F901AD0D77B8.bk_
Sending boot... OK
Erasing flash memory OK
Sending firmware OK
Searching for phone... found S Flash Neptune LTE2
Reading phone boot version... 0.00
Reading flash id... Intel - 28FL18B
Reading flash id/2... Intel - 2256L18T, OK
Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3
Hardware IMEI: 3517800737725
IMEI OTP status: locked
Security area saved to "PDS for S Flash Neptune LTE2 3517840217705.mbk"
Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F901ADF5E77B8.bk_
Restore OK
Unlocking phone... OK
Turning phone off... OK
Thanks smart-clip...TEAM...
The Following User Says Thank You to khurram86 For This Useful Post:
Old 02-24-2009, 21:19   #2 (permalink)
oMeR_Rasheed's Avatar
Member: 466635
Sonork: 100.1614186
Thanks Meter: 482
Originally Posted by khurram86 View Post
it 100% works
no signal problem
searching for phone... Found motorola phone (w490), getting test interface... Ok
model w490
firmware r452g_g_08.24.02r
switching to flash mode... Ok [s flash neptune lte2]
reading phone boot version... C.50
sending boot... Ok
stored temporary backup to c:\program files\gsmserver\smartmoto\temporary backup\bkp_f901ad0d77b8.bk_
sending boot... Ok
erasing flash memory ok
sending firmware ok
searching for phone... Found s flash neptune lte2
reading phone boot version... 0.00
reading flash id... Intel - 28fl18b
reading flash id/2... Intel - 2256l18t, ok
phone group: V235,v360,v360v,v3i,v3r,l7,l7e,l7v,l71,l72,l9,k1,u 3,w5,w490,w510,z3
hardware imei: 3517800737725
imei otp status: Locked
security area saved to "pds for s flash neptune lte2 3517840217705.mbk"
performing restore from temparary backup file c:\program files\gsmserver\smartmoto\temporary backup\bkp_f901adf5e77b8.bk_
restore ok
unlocking phone... Ok
turning phone off... Ok
thanks smart-clip...team...
how can thi possibale before some mobiles unlock done butt after unlock no l.c.d light how can i understand this pease can u explain me how to unlock this phon whit prepear our unlock via tp section please
b.r
sherry mobiles
Old 02-24-2009, 21:29   #3 (permalink)
Nustian's Avatar
Member: 302566
Sonork: 1579334:100.1.100
Thanks Meter: 42
I unlok 2 W490 Today pefetly.no Lcd nor signal problem.
Br:- Awais
Old 02-25-2009, 03:16   #4 (permalink)
tavoonly's Avatar
Member: 586318
Thanks Meter: 112
Br:- Awais
Would you be so kind to explain the full process to unlock it via tp and no by prepare method. 'cause I have tried so many times but I always got an "io timeout" error message.
Thanks and BR
Old 02-25-2009, 10:15   #5 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
b.r
sherry mobiles
If you don't get the LCD back light then check the PCB. I am sure you damaged it while was trying to perform TP connection. The only thing i can suggest - be more careful next time.
Best Regards
GSMServer team
Old 02-25-2009, 10:20   #6 (permalink)
Member: 121052
Sonork: 100.107126
Thanks and BR
Please specify, what exactly model did you try to unlock? What was boot and fw version of this phone?
In most cases the message "io timeout" informs about low power lever whether on Smart-Clip or the phone.
Just to be sure, please reply to specified above questions.
Best Regards
GSMServer team
Old 02-25-2009, 10:24   #7 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
http://smart-clip.com/support.php#Smart_TP
Testpoint picture is located in www.boot-loader.com, Public Downloads -> Filelists -> Testpoints
Old 03-03-2009, 03:18   #8 (permalink)
Member: 985167
help me please, was unlock a motorola w490, I spent the falsh and the release was done but when I started to flesh it died again (no more links) but is recognized in flash bike, how can I reinstall it? or make it live again? help me.
Old 03-03-2009, 08:04   #9 (permalink)
Member: 219732
Thanks Meter: 9
hi bro what is your best technic to lift off the shield cover of that phone?
Old 03-03-2009, 08:42   #10 (permalink)
Member: 121052
Sonork: 100.107126
Also, please show the log file without serials.
Best Regards
GSMServer team
Old 03-04-2009, 08:42   #11 (permalink)
khurram86's Avatar
Member: 682981
Sonork: 100.1587606
Thanks Meter: 116
b.r
sherry mobiles
ok Try this solution
http://http://rapidshare.com/files/2.../w490.JPG.html
100%%%%%%% working
Old 06-08-2009, 11:30   #12 (permalink)
ATIEFUOR-GSM's Avatar
Member: 132856
Thanks Meter: 36
100%%%%%%% working
hi
bos link not working
pls upload again
thanks
Old 08-28-2009, 03:32   #13 (permalink)
Member: 508513
ok try this solution
http://http://rapidshare.com/files/2.../w490.jpg.html
100%%%%%%% working
the link not work bro
Old 09-01-2009, 06:48   #14 (permalink)
Member: 977491
Thanks Meter: 82
Cool GOOD WORK.....plz send me any body pinouts of w490 tp
send me also that how i can download new flash files
Old 09-01-2009, 06:55   #15 (permalink)
Member: 977491
Thanks Meter: 82
GOOD work . some one send me w 490 tp .
plz also help me about downloading flash files for smart clip.
e75 unlock done by safety unlock by codes via server GUDO-GSM MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-02-2010 17:09
W490 unlock done with tp in 30 seconds...no signal , no display problem himanshu taldar MSS Box II 2 02-25-2009 17:10
W490 t mobile unlocked done by smart motto. ALEXIS_089 Motorola P2k 2 02-07-2009 09:17
w490 unlock done right_click Smart-Clip 3 01-10-2009 08:32
K810i Unlock Done By Javaunlocker By Ub Box ayhen42 Universalbox 2 08-29-2008 11:24
Page generated in 0.25705 seconds with 9 queries
