11-03-2007, 08:28 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | L6 after full flash now is dead? i have one L6 before flashing mobile was ok just mp3 was playing slow and video songs was ok boot loader was r3511-g-0a.53.15r i just do repair pds then prepare and then full flash with boot loader r3511-g-0a-52.26r-b-lp0051 and now set is not going to on only keypad lights blink i have try also with r3511-g-0a(1)52.26r-b-lp0959 but nothin happed needed solution to alive and i use smf files |
11-03-2007, 08:48 | #2 (permalink) | |||
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
R3511_G_0A.53.1AR R3511_G_0A.53.1BR R3511_G_0A.53.1CR | |||
The Following User Says Thank You to mcandre For This Useful Post: |
11-03-2007, 09:17 | #3 (permalink) |
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | i have try with R3511_G_0A.53.15R 18mb file and name was .mfw but nothin happened and i know i do wrong procedure coz i was hurry |
11-03-2007, 09:25 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ makkah mobile, Please try to perform Repair PDS procedure and after that Full Flash the phone with R3511_G_0A.53.1CR. Also, please show us log file from flashing procedure, without serial number. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-03-2007, 09:44 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ makkah mobile, Use *.mfw full flash file. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-05-2007, 17:54 | #7 (permalink) |
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | problem not solve seee this SmartMoto 2.38 S-Card: hhhhhhhhhh Smart-Clip dongle, v 1.49, assigned Smart-Clip: hhhhhhhh Europe, initializing... OK Clip serial: hhhhhhhhhhh, version: 3.25, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 8.D5 Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 8.D5 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK Reading phone boot version... 2.00 Reading flash id... ST - M30L0R8000B0 Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 351951011641080 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE 351951011641080 (5).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Login request... OK Writing flash section 4 of 4... 100% (12.6 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (19.3 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (69.9 Kb/sec) Turning phone off... OK Flash completed! |
11-05-2007, 18:38 | #9 (permalink) |
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | dear kashi without prepare we can not flash the phone i m doing flash with first prepare then repair pds and then full flash i m not using testpoint i m doing flash with prepare .....thnks |
11-05-2007, 21:31 | #10 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Ecuador -Andes
Member: 331361 Status: Offline Thanks Meter: 155 | try -preparate cyrcle -repair pds -change bootloader at 8.d0 -flash with *pcf file. or in one case for me work flashing with v195 file, with it do not turn on display, but after life phone i flashing with l6 file it in *.pcf files. |
11-06-2007, 10:36 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ makkah mobile, As can be seen from the log file all procedures were perfomed properly. In such case most probably that the handset has some hardware malfunction. By the way, why you use old version of S-Card and SmartMoto? Try to update to the latest versions and run al procedures once again. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-06-2007, 20:16 | #13 (permalink) | |
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | Quote:
u mean in this versions of moto is any problem i have almost flash 5 pices L6 with this version but y is not going to alive this one L6 b,coz b4 flashing L6 was alive ........ | |
11-07-2007, 08:57 | #14 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ makkah mobile, I'm not sying that some version of software has any problem. Each version get tested before update. We always recommend to use latest versions of the software. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by GSM_Support; 11-07-2007 at 10:37. |
11-07-2007, 10:12 | #15 (permalink) |
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | today i flash L6 with L7 flash file after full flash phone goes direct in boot loader and showing code error i mean when i insert battery phone goes direct in boot loader and showing code error and after that i flash again L6 files R3511-g-0a.53 1cr and goes back just keypad lights blinking |
my x150x after unlock now is DEAD | cllins | Infinity-Box | 1 | 02-04-2009 20:14 |
after unlock my w180 now is dead | hans salim | Rocker Dongle (By Legija) | 2 | 09-05-2008 14:41 |
sagem 226 after unlock now is dead | MOBIFEMI | FuriousGold | 7 | 04-09-2008 20:46 |
6280 after few trys now is dead | ayubalikhan | BB5BOX | 13 | 12-20-2007 22:44 |
what problem now i flash 6280but after full flash start up only nokia withe hang .... | saray | Nokia Hardware & Hardware Repair | 3 | 04-12-2007 00:18 |
