L6 Pink Flash File..... Can I use the standard flash file for the standard L6 on a PINK L6, this is the firmware version currently in the pink L6 R3511_G_0A.52.2BR_A & this is the file I want to flash to it R3511_G_0A.52.26R_B Anybody tell me if I will have any problems as the customer was having problems with the phone freezing when she wanted to text someone. BR thcoms |
@ thcoms, You can try to flash the phone with that Flash file. But before flashing make a backup, just in case. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
OK, I tried to back up the original flash on this handset but got this error message.... Clip serial: -----------8, version: 2.26, initializing... OK Searching for phone... found Motorola Phone (L6), getting test interface... OK Model L6 Firmware R3511_G_0A.52.2BR_A Reading info OK Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.D0 Boot prepare... failed Clip serial: ----------8, version: 2.26, initializing... OK Searching for phone... found Motorola Phone (L6), getting test interface... OK Model L6 Firmware R3511_G_0A.52.2BR_A Reading info OK Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.D0 Boot prepare... failed So I tried to flash the phone by normal mode then testpoint & got this error.... SmartMoto 1.23 Clip serial: ----------8, version: 2.26, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... 0x0000-0x0802 Phone group: V30x,V40x,V50x,V52x,V60x Reading OTP... error B8 Warning: OTP read failed Turning phone off... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Clip serial: -----------8, version: 2.26, initializing... OK Searching for phone... found Motorola Phone (L6), getting test interface... OK Model L6 Firmware R3511_G_0A.52.2BR_A Reading info OK Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.D0 Boot prepare... failed Reading phone boot version... io timeout Reading phone boot version... io timeout Where have I gone wrong? BR thcoms |
@ thcoms, First log file: TP wasn't done properly/ Second log file: Flash chip wasn't made properly. There are 2 main reasons for such error: 1.) The phone has hardware malfunction. 2.) TP wasn't made properly. Make sure that you do everything correctly, and try once more. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
