12-03-2006, 13:21 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: U.K. Age: 56
Member: 142512 Status: Offline Thanks Meter: 2 | L6 Pink Flash File..... Anybody tell me if I will have any problems as the customer was having problems with the phone freezing when she wanted to text someone. BR thcoms |
12-04-2006, 09:57 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ thcoms, You can try to flash the phone with that Flash file. But before flashing make a backup, just in case. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-04-2006, 16:03 | #3 (permalink) |
Member: 142512 Status: Offline Thanks Meter: 2 | OK, I tried to back up the original flash on this handset but got this error message.... Clip serial: -----------8, version: 2.26, initializing... OK Searching for phone... found Motorola Phone (L6), getting test interface... OK Model L6 Firmware R3511_G_0A.52.2BR_A Reading info OK Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.D0 Boot prepare... failed Clip serial: ----------8, version: 2.26, initializing... OK Searching for phone... found Motorola Phone (L6), getting test interface... OK Model L6 Firmware R3511_G_0A.52.2BR_A Reading info OK Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.D0 Boot prepare... failed So I tried to flash the phone by normal mode then testpoint & got this error.... SmartMoto 1.23 Clip serial: ----------8, version: 2.26, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... 0x0000-0x0802 Phone group: V30x,V40x,V50x,V52x,V60x Reading OTP... error B8 Warning: OTP read failed Turning phone off... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Clip serial: -----------8, version: 2.26, initializing... OK Searching for phone... found Motorola Phone (L6), getting test interface... OK Model L6 Firmware R3511_G_0A.52.2BR_A Reading info OK Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.D0 Boot prepare... failed Reading phone boot version... io timeout Reading phone boot version... io timeout Where have I gone wrong? BR thcoms |
12-04-2006, 16:09 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ thcoms, First log file: TP wasn't done properly/ Second log file: Flash chip wasn't made properly. There are 2 main reasons for such error: 1.) The phone has hardware malfunction. 2.) TP wasn't made properly. Make sure that you do everything correctly, and try once more. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
it is possible flash l6 r3511 with l6 r3517 flash file ? | hamid123 | Smart-Clip | 1 | 11-12-2007 08:55 |
L6 unlock/Flash file problem.......... | vipimg | Smart-Clip | 4 | 06-01-2007 06:40 |
L6 Turkish Flash File With Pst | erayturkoglu | Motorola P2k | 17 | 05-23-2006 14:39 |
V3 Pink Flash File? | thcoms | Smart-Clip | 31 | 01-29-2006 16:54 |
