03-05-2009, 04:39 | #1 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | L6i clip communication failed phone power boot only but if u repair pds error like this: Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... Intel - 28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 354079010775944 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE 354079010775944 (7).mbk" Login request... OK Writing flash section 1 of 4... 24% (32 Kb/sec) clip communication failed |
03-05-2009, 08:37 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | In case of getting an error "Clip communication failed", while detecting the handset, please check the output of Smart-Clip power source. For stable Smart-Clip unctions minimum output 10V & 1A. The adapter is available here. Some phone models use a data cable for charging. So, as soon as it gets connected to Smart-Clip it starts charging and uses about 500mA, plus Clip requires another 130-150mA. Regarding SCout Flasher, please flash your phone with Full Flash file. ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com |
03-05-2009, 09:22 | #5 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | L6i flash problem Quote:
you are flashing phone with reflash file, download from support full flash file and use full charged battery only, not use power supply, if you use power supply u will get clip communication failed error some times. test and post result mianlinks | |
03-06-2009, 09:27 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | What exact power supply do you use? Did you read this post ? ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com |
03-15-2009, 04:25 | #8 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | after buying this http://gsmserver.com/shop/equipment/...er_adaptor.php same problem: using this L6i_R3443H1_G_0A.65.0BR_lp0021_GSVL6IHG00014X(...) 18.82 Mb L6i_R3443H1_G_0A.65.0BR_lp0021_full_flash.mfw 18.88 Mb L6i_R3443H1_G_0A.65.0BR_lp0021_reflash.mfw same problem: |
03-16-2009, 08:58 | #10 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | As i can see from all pictures, the handset got detected as S Blank. That's not normal, if the phone is connected without use of TestPoint. Your phone may have a hardware problem that's why all errors appear. There is not bug in software. Best Regards GSMServer team |
03-17-2009, 01:19 | #11 (permalink) | |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
try change change if problem is same post later............. | |
smart-clip team; clip communication fail during v3 pds repair | GOODNESS | Smart-Clip | 2 | 08-17-2006 10:39 |
clip communication failed while flashing !!!! | bayleaf | Smart-Clip | 1 | 12-22-2005 23:50 |
reading flash id..clip communication failed | GuilleB | Smart-Clip | 10 | 11-23-2005 13:47 |
Clip Communication Failed | lc5829 | Smart-Clip | 4 | 08-05-2005 03:56 |
Motorola C350 smart-clip " clip communication failed | jamsab18 | Smart-Clip | 6 | 01-24-2005 23:58 |
