05-07-2009, 02:07 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 567388 Status: Offline Thanks Meter: 24 | l7 boot loader appear when inserting battery. any body can help me |
05-07-2009, 03:12 | #6 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,054 | Prepare phone or Connect via TP, if it detecst phone go to Flash Tab, Load the Boot version it had then Flash. |
The Following User Says Thank You to xerraco For This Useful Post: |
05-07-2009, 03:46 | #8 (permalink) |
Member: 890926 Status: Offline Thanks Meter: 2,054 | Maybe Mate, but some Moto phones can be revive if you flash it the Original version it had, but its hard to guess w/c Firmware is it. |
05-07-2009, 04:09 | #9 (permalink) |
Member: 567388 Status: Offline Thanks Meter: 24 | but when i downgade i use this version.. R4513_G_08.B7.E0R_RB_lp0032_full_flash.mfw it back to his original problem which is blinking on keypad lights only.... and when you hold *# and power has appear the boot version... |
05-07-2009, 07:42 | #10 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | What FW version the handset originally had? Was it R4517_G_08.C4.1ER? You can flash the same or newer FW version with the same platform (R4517). Why are you downgrading FW? Check FW version on sticker under the battery. Now you can repair PDS again, full flash the handset with the highest version of R4513 file, then perform Restore IMEI (do not disconnect and/or turn off the handset before applying Restore IMEI option) ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com Last edited by GSM_Support; 05-07-2009 at 09:13. |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
L7 boot loader 09.02. | amps_jas | Ultima Box Light | 4 | 11-07-2009 04:58 |
L7 bootloader when inserting battery | justine54 | Smart-Clip | 5 | 05-21-2009 07:47 |
L7 Boot Loader Only Success Flash By Mssbox2 | SANGURAN_BOX | MSS Box II | 0 | 05-27-2008 09:56 |
K1 shows up Boot Loader screen when insert battrey or power up... | Burnt Cobba | Smart-Clip | 8 | 04-03-2007 21:52 |
L7 boot loader | ashrafcell | Motorola Hardware Repair | 1 | 01-19-2007 06:33 |
