01-30-2007, 17:54 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: www.themobilephonesite.com Age: 44
Member: 105154 Status: Offline Thanks Meter: 2 | MEM_MAP Blank Service Req'd ----HELP---- I tried to unlock my Moto V360 using my smart clip, S card & Moto Smart. I used the prepare phone section to try and unlock the handset without test point. connected to the phone fine etc and the software did it's stuff, but now the handset will not boot up. It is stuck in boot loader the software is R4513_G_08.B7.56R_A. The handset also says MEM_MAP Blank Service Req'd what is that, and how can I retrive the handset. Thank you |
01-30-2007, 18:32 | #3 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | donīt need to flash phone I have same issue a lot of times. just donīt close smartmoto, donīt click on search phone and click Prepare one more time. If u press search or close soft it will not recognice the temporary backup. best regards. |
02-13-2007, 12:25 | #5 (permalink) |
Crazy Poster Join Date: Aug 2005 Age: 64
Member: 170987 Status: Offline Thanks Meter: 2 | i had same problem about 5 mins ago with a V3i saying MEM_MAP Blank Serivice required after trying to unlock without testpoint, only solution i had was to:- 1 - unlock via testpoint (phone will still have bootloader saying MEM_MAP Blank Serivice required) 2 - reassemble the phone andprepare the phone without the unlock tab ticked and all should be ok, worked for me |
02-13-2007, 12:52 | #7 (permalink) | |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Quote:
There is no need to perform any TestPoint in this case! If there was any mistakes made during unlock process, and the handset is in "MEM_MAP Blank" mode, then "Prepare" process has to be repeated and the handset has to be flashed with reflash or full_flash file. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
02-13-2007, 20:53 | #9 (permalink) | |
Registered User Join Date: Aug 2003 Location: Argentina
Member: 36880 Status: Offline Thanks Meter: 1 | Quote:
02-14-2007, 08:33 | #11 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ tajofer, Try to make Repair PDS and after that Full Flash the handset. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-14-2007, 11:03 | #12 (permalink) |
No Life Poster Join Date: Jun 2005 Location: rawalpindi,pakistan.
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | V3rohs In Boot Mode Now HI M8 I TRY 1 V3ROHS LIKE V3R MATHOD BUT AFTER THAT I GOT MY PHONE IN BOOT MODE. HERE IS THE THE LOG FILE . SmartMoto 2.17 S-Card: 3********* Smart-Clip dongle, v 1.13, assigned Smart-Clip: ********* Europe, initializing... OK Clip serial: *********, version: 3.13, initializing... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.30 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7v,K1 Hardware IMEI: 359419002642337 Security area saved to "PDS for S Blank Neptune LTE2 359419002642337 (12).mbk" Unlocking phone... OK Now you should write flash into the phone Login request... OK Writing flash section 2 of 2... 100% (36.9 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (13.6 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Error: file flash data (48 Mb) does not suite phone memory WAITING FOR YOUR QUICK REPLY. REGARDS NAEEM PAKISTAN |
02-14-2007, 11:09 | #13 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ naeem janjua, what firmware version your phone originally had? Try to flash the handset with exactly the same firmware that it had from the beginning. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-14-2007, 13:32 | #14 (permalink) | |
V3i MEM_MAP Blank Service Req'd ... please Help | aliraqi | Smart-Clip | 3 | 01-09-2009 10:18 |
Unlocking L7 with MEM_MAP Blank Service req'd... | zeppelin79 | Smart-Clip | 2 | 07-25-2008 09:08 |
v525 MEM_MAP Blank Service Req'd | moie70 | Ultima Box Light | 5 | 09-07-2007 10:22 |
V360v MEM_MAP Blank Service Req'd | maverick_lp28 | Ultima Box Light | 1 | 08-09-2007 23:33 |
V3i MEM_MAP Blank Service REQ'D | Phoneze | Smart-Clip | 1 | 02-06-2007 23:28 |
