09-03-2008, 13:10 | #1 (permalink) |
No Life Poster Join Date: Oct 2000 Location: Split / Zagreb, Croatia Age: 53
Member: 2236 Status: Offline Thanks Meter: 58 | moto K1 write problem... yesterday I tried to unlock two pieces and both dead because unlock procedure was not finished... tried to write back PDS, tried to flash, tried to write back boot and can't write anything because preparing is going well but finishing is impossible... here I tried write back boot: SmartMoto 3.16 S-Card: 55******* Smart-Clip dongle, v 2.10, assigned Smart-Clip: 72******* Europe, initializing... OK Smart Adaptor: serial 19*******, firmware version 1.05 Clip serial: 72*******, version: 4.08, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... Intel - 28F256L18T, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 354516010764758 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 35451601******* (1).mbk" Writing flash section 1 of 1... 9% io timeout whatever I do or try, boot, flash, write PDS it is always Writing flash section 1 of 1... 9% io timeout sometimes stops at 3%, sometimes 12%, sometimes even 19% battery is full charged..., testpoint is OK... any solution for this write error... . |
09-03-2008, 13:13 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Spalato, Please tell us what power supply you are using with the Smart-Clip. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-03-2008, 14:00 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Spalato, Such error usually appears in case if the battery of the phone wasn't fully charged, Smart-Clip power supply has low output/not stable output or the phone has some hardware malfunction (some specific sectors can not be read/written). Try to perform flashing procedure once again. Before perfroming operation please check such settings: 1. Fully charge the battery, as an option try to use another one. 2. Ensure that the power supply you use provides stable output. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
moto k1 display problem | jay_patel3 | Motorola Hardware Repair | 3 | 07-29-2009 15:20 |
moto k1 big problem | omkarvitekar | Motorola Hardware Repair | 0 | 11-07-2008 17:20 |
moto k1 problem | gmx | Motorola P2k | 1 | 11-27-2007 02:41 |
moto k1 unlocking problem | legendmani | Motorola Hardware Repair | 2 | 04-26-2007 08:41 |
