02-23-2009, 07:53 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: in gsm world
Member: 269885 Status: Offline Thanks Meter: 50 | moto v3 flash problem bootloader 07.E0 sw version R374-G-0E.40.79R i repaird its pds and flashed wid above version but no success,den i flashed wid pcf formate of above version but hv no result.i also flashed wid R374_G_0E.42.10R_A_lp0034_full_flash.mfw but fone at its initial state.i chkd its bootloader after every flash but it showd always bootloader 07.E0 sw version R374-G-0E.40.79R wats the problem going on and wats its solution.help needed the last operation log is SmartMoto 3.20 S-Card: 131xxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: 172xxxxx Europe, initializing... OK Clip serial: 172xxxxx, version: 4.08, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel - 28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 351970015951006 IMEI OTP status: locked Security area saved to "PDS for S Flash Neptune LTE 351970015951006.mbk" Login request... OK Writing flash section 4 of 4... 100% (7.03 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 2 of 2... 100% (42.7 Kb/sec) Flash completed! Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel - 28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 351970015951006 IMEI OTP status: locked Security area saved to "PDS for S Flash Neptune LTE 351970015951006 (1).mbk" Writing flash section 1 of 1... 100% (27.9 Kb/sec) Flash completed! Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... Intel - 28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 356258007834793 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE 356258007834793 (2).mbk" Login request... OK Writing flash section 4 of 4... 100% (5.66 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 2 of 2... 100% (47.7 Kb/sec) Flash completed! |
The Following User Says Thank You to burraq For This Useful Post: |
02-23-2009, 11:10 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | It would be great if could have an idea what has previously happen to this handset, so it got to this state. Try performing the same procedure again (PDS, full_flash) and right after flashing apply IMEI Repair Firmware Patch. When the handset turns ON restore original number using SmartMoto. Best Regards GSMServer team |
02-24-2009, 09:05 | #3 (permalink) |
Member: 269885 Status: Offline Thanks Meter: 50 | the fone came at that condition and costomer said that he didnt known about that. but the question is this why fone not accepted the difrnt files. any idea about that |
02-24-2009, 14:06 | #4 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Sorry, i don't quite understand, what exactly do you mean? What flash files did you flash to it? Best Regards GSMServer team |
02-25-2009, 10:51 | #6 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | The information about fw version on the phone's screen will change only after the handset is power ON to normal mode. As yours can only turn on to flash mode - the version doesn't change. Regarding your question, why the phone doesn't power on after flashing - there could be a lot of reasons for it. First of all, try finding out what has initially happened to the phone, so it got to this state? Possibly the phone has a hw damage and flashing will never solve it. Best Regards GSMServer team Last edited by GSM_Support; 02-25-2009 at 10:58. |
Moto v3 display problem | sribalaji | Motorola Hardware Repair | 6 | 01-02-2010 16:06 |
Moto v3 charging problem | sribalaji | Motorola Hardware Repair | 2 | 10-11-2009 04:12 |
moto v3 flash file needed please | rhimark | Motorola P2k | 1 | 03-08-2009 07:04 |
Moto V3 Keypad problem. | amol_sm | Motorola Hardware Repair | 8 | 09-07-2008 18:06 |
How to get teh MOTO V3 flash and BLUETEETH module | ldlicen1029 | Motorola Hardware Repair | 0 | 05-21-2006 21:21 |
