02-01-2009, 15:50 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 251401 Status: Offline Thanks Meter: 2 | Moto v557 repair pds getting error 9b & error 19f.pls help sc team MY SMART CLIP LOG IS HERE. SmartMoto log REPAIR WITH USB SMART ADAPTOR : SmartMoto 3.20 S-Card: xxxxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxxxx Europe, initializing... OK Smart Adaptor: serial xxxxxxxxx, firmware version 1.05 Clip serial: XXXXXXXXX, version: 4.08, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 2.00 Reading flash id... Intel - 28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 359410001992799 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE 359410001992799 (10).mbk" Writing flash section 4 of 4... 100% (9.48 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK IMEI OTP status: locked Performing PDS repair... error 19F SmartMoto log REPAIR WITH LPT CABLE : SmartMoto 3.20 S-Card: XXXXXXXXX,Smart-Clip dongle, v 2.10, assigned Smart-Clip: XXXXXXXXX,Europe, initializing... OK Clip serial: XXXXXXXXX, version: 4.08, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 2.00 Reading flash id... Intel - 28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: 359410001992799 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE 359410001992799 (18).mbk" Login request... OK Writing flash section 4 of 4... 100% (9.45 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... error 9B PLS HELP ME SMART CLIP TEAM TO GET REPAIRED PDS ON V557. WITH REGARDS. |
02-02-2009, 09:34 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Please provide us with answers to the following questions:
Best Regards GSMServer team |
02-10-2009, 16:25 | #3 (permalink) |
Member: 251401 Status: Offline Thanks Meter: 2 | i had used 12volts 1amp power supply adaptor for smart clip i used standard cable yes the lcd was disconnected please give me some solution to repair pds on v557. with regards. |
02-13-2009, 06:23 | #5 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 711273 Status: Offline Thanks Meter: 81 | unlocking v3re afterunlock error9b please Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... ST - M58LR256A Phone group: V3re,K1/s Hardware IMEI: 351799029929264 IMEI OTP status: locked Security area saved to "PDS for S Flash Neptune LTE2 351799029929264 (2).mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F90195DFE37932D5.bk_ Restore OK Unlocking phone... error 9B |
02-13-2009, 10:18 | #6 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Please provide us with answers to the following questions:
___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com |
08-05-2009, 19:16 | #7 (permalink) |
No Life Poster Join Date: Nov 2003 Location: kjhjk Age: 50
Member: 43253 Status: Offline Thanks Meter: 157 | Same issue I had the same issue with one V3re and seem that there was a problem in the connector of the phone, because when I move the cable the box work perfect and I had to put the cable in a position and try donīt move, prayed, prayed, and BINGO after to many hours and many error message I could do it (in each error message I had to start from the begining). I attempted with one w510 to read info and put in flash mode and there was not problem. For example, when I got the message 19f or other error message reading the info with the V3re I change the cable to the w510 and not problem to read info. If, when you connect the phone direct to the PC and get the message Uknow Device or "There was a problem connecting the device" (I donīt remember exactly), then there is a connection problem or cable problem, please correct me if I wrong. I hope donīt have any problem with other phones and my BOX be right. |
03-11-2010, 18:26 | #8 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Egypt_Cairo Age: 41
Member: 111140 Status: Offline Thanks Meter: 75 | I have same erorr SmartMoto 4.05 S-Card: xxxxxxxxxxxxxSmart-Clip dongle, v 3.03, assigned Smart-Clip: xxxxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxx, version: 5.02, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel - 28F256L18B Phone group: A630,E1,E37x,E39x,E55x,L6,U6,V3,V190,V330,V53x,V54 x,V55x,V62x,V635,V80 Hardware IMEI: xxxxxxxxxxxxxxxxxxxxxxx IMEI OTP status: locked Security area saved to "PDS for S Flash Neptune LTE xxxxxxxxxxxxxxxxx (8).mbk" Login request... OK Writing flash section 4 of 4... 100% (7.41 Kb/sec) Restarting phone... OK Searching for phone... found S Flash Neptune LTE Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... error 9B I have Standard P2K cable Batary i am not make test point GsmOrient |
03-12-2010, 08:25 | #9 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ GsmOrient, Provide us with more detailed information. What is wrong with the phone? Why are you trying to perform Repair PDS procedure? Best Regards GSMServer team |
V557 Repair PDS fail..........???? | Littlemaster | Smart-Clip | 34 | 10-27-2008 08:48 |
moto l6 repair pds error | burraq | Smart-Clip | 1 | 02-05-2008 08:44 |
Moto E2 Repair PDS ?? | jhon32272 | Smart-Clip | 0 | 11-14-2007 16:44 |
V3 Bootloader Screen-did Repair Pds-then Tried Flash -an Error-help | zonetrichur | Smart-Clip | 6 | 10-30-2007 09:07 |
GOT Moto Cannot Repair PDS of L7i | cordagz | GOT Motorola | 0 | 10-19-2007 08:44 |
