01-28-2007, 13:14 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 45
Member: 71874 Status: Offline Thanks Meter: 34 | Motorola V3r Dead during testpoint I was trying to unlock the Motorola V3r (0A.52) using testpoint but when cutting the shield i think i have damaged the resistor near the testpoint (see picture). The handset no longer powers on and is completely dead. Is there any way to resurrect this phone? Smartclip cannot detect the phone! Thanks Majid www.mobilekrazy.com |
02-03-2007, 00:20 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 50
Member: 104911 Status: Offline Thanks Meter: 42 | you can fix this problem if you get your meter out and do some testing. have you fixed the phone? also its not a resistor its a capacitor you have ringed and its connected in parallel to the one to the left of it. we have seen many dead phones like this. br |
02-04-2007, 12:11 | #6 (permalink) | |
Member: 71874 Status: Offline Thanks Meter: 34 | Quote:
Thanks Majid www.mobilekrazy.com | |
02-04-2007, 12:17 | #7 (permalink) |
Member: 104911 Status: Offline Thanks Meter: 42 | ok, you have shorted the cap (this happens mostly when people do the test point but leave the shield touching down on it and hence shorts it out, then when you power the phone is dies), but the one to the left of it is in paralell with it, so just remove the cap you have circled. br |
02-04-2007, 14:54 | #8 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | missing caps does not power off a phone unless it is grounded its better to test phone if it still powers on after removing the metal cover, you can use another board to test where are this cap is connected to. try to use a magnifing lenss to check damaged lines. (ripped off from the phones board) sorry i cant help more best regards Mansi |
02-04-2007, 14:57 | #9 (permalink) | |
Member: 104911 Status: Offline Thanks Meter: 42 | Quote:
please read again, the problem is the cap has gone short, there are two caps in parallel one of them has gone short. remove it and the phone will work, tested many times. regards | |
02-04-2007, 15:57 | #12 (permalink) |
Member: 71874 Status: Offline Thanks Meter: 34 | Thanks guy, the damage was to the capacitor not resistor. I'll change and let you know the details. Thanks Majid www.mobilekrazy.com |
02-08-2007, 17:37 | #14 (permalink) |
Member: 71874 Status: Offline Thanks Meter: 34 | Thanks for all who responded. The handset has been revived after replacing the capacitor. I won't be doing any more manual testpoints!!! Thanks Majid www.mobilekrazy.com |
02-13-2007, 08:49 | #15 (permalink) | |
Member: 71603 Status: Offline Thanks Meter: 31 | Quote:
here my log: Searching for phone... found Motorola Phone (V3r), getting test interface... OK Model V3r Firmware R3443U2_G_0E.C0.13R Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7v,K1 Hardware IMEI: 3525090xxxxxxx Security area saved to "PDS for S Blank Neptune LTE2 3525090xxxxxxxx.mbk" Unlocking phone... OK | |
Motorola V3r dead after unlocking | rudelay | Motorola P2k | 4 | 12-07-2009 16:06 |
v3r dead during unlocking process | mobilecraker | Smart-Clip | 5 | 01-21-2009 14:08 |
V3r dead using testpoint and smart clip | RolandoMota | Smart-Clip | 6 | 05-07-2008 11:45 |
v3r dead during unlocking | paklink | Smart-Clip | 1 | 05-23-2007 14:17 |
Motorola V3r Unlocking using testpoint (0A.52) | bbmad | Ultima Box Light | 20 | 03-13-2007 10:22 |
