Motorola V3re Dead After Smart Testpoint hi, i tried to unlock a motorola v3re, with smart testpoint, when it asked me to make smarttestpoint, it gives a conection error, tells me check if conected correct cable and retry, but i tried with both the yellow and the green cable, and no one of them work, so now i have the phone in boot mode, and i need to make it work, the question is, if i need to have scout to flash it, or if i can do it with smartclip the bootloader is 0c.c1 sw R3442A_G_0E.43.04R |
Man Which Smart Testpoint Are You Using If Is Not From Gsmserver Than You Are Warn.bad Smart Testpoint Kills Phone I Have Same Problem Which I Have Kill Two Phone With Bad Smart Testpoint From Gpg.so Check Smart Testpoint |
what if fone is not in testmode .. and total blank dead .. is there any chance to revive it back ? |
@ luckycool, In case if the phone can be detected by PC, you can try to Full Flash it with the same firmware version like it originally had. http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
nnaah .. phone is not detected by pc mate ,, stuck somewhere :( |
Hi I had the same problem test point the phone and the computer will see it. Then flash with original flash file. This worked for me. BR |
after unlok set dead no boot mode no scont detact helip me............... |
@ jimmykumar, If Argon or LTE2_ROM4 phone model can not be detected at all, more likely that it has some hardware malfunction. Please check the PCB of the phone. http://www.gsmserver.com/img/sc_userbar_1.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
pcb is ok tepoint is ok but no boot mode |
calm down check the phone properly, put it back and turn it in flash mode and repeat the unlocking process.....if error occur fullflash the phone by using scout..... if phone still not detected.... you are in big trouble.....:eek: |
what is important your phone still detected by smartmoto.... maybe your phone is in blank... if it is.....continue the unlocking proccess.... just take it slow brother.... |
