10-19-2007, 20:57 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: United States Age: 50
Member: 259133 Status: Offline Thanks Meter: 22 | Motorola V3re Dead After Smart Testpoint when it asked me to make smarttestpoint, it gives a conection error, tells me check if conected correct cable and retry, but i tried with both the yellow and the green cable, and no one of them work, so now i have the phone in boot mode, and i need to make it work, the question is, if i need to have scout to flash it, or if i can do it with smartclip the bootloader is 0c.c1 sw R3442A_G_0E.43.04R |
10-20-2007, 07:13 | #2 (permalink) |
No Life Poster Join Date: Mar 2006
Member: 241831 Status: Offline Thanks Meter: 18 | Man Which Smart Testpoint Are You Using If Is Not From Gsmserver Than You Are Warn.bad Smart Testpoint Kills Phone I Have Same Problem Which I Have Kill Two Phone With Bad Smart Testpoint From Gpg.so Check Smart Testpoint |
11-22-2007, 13:59 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ luckycool, In case if the phone can be detected by PC, you can try to Full Flash it with the same firmware version like it originally had. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-14-2008, 16:23 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ jimmykumar, If Argon or LTE2_ROM4 phone model can not be detected at all, more likely that it has some hardware malfunction. Please check the PCB of the phone. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-14-2008, 16:41 | #10 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: Inside your Dreams
Member: 551782 Status: Offline Sonork: 001135666 Thanks Meter: 59 | Quote:
calm down check the phone properly, put it back and turn it in flash mode and repeat the unlocking process.....if error occur fullflash the phone by using scout..... if phone still not detected.... you are in big trouble..... | |
V3re dead after clip communication failed | dormi81 | Smart-Clip | 12 | 05-23-2008 07:45 |
W490 W510 V3re Dead after unlock attempt | mishaelwillo | Smart-Clip | 34 | 02-22-2008 09:36 |
pluse help motorola v1100 dead after prapare smart clip | alirag | Smart-Clip | 2 | 10-22-2007 13:26 |
Motorola V235 dead after unlock by Smart-Clip | emwugsm | Smart-Clip | 6 | 09-02-2006 00:14 |
Motorola L6 dead after testpoint | agronx | Smart-Clip | 5 | 05-07-2006 13:54 |
