Motorola V3x not unlocking I use TP and always get same error,i've done many but having problems with 2 pieces. Here is log Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... 0x0070-0x00B1 (x2) Phone group: A835,A845,A920,A925 Internal error 0001 |
some times v3x can be a pain as i can see in your log that it hasn't detected the right group so keep trying till it says ok i had a problem on c975 and every time was an error but didn't give up so got sorted at the end good luck br |
full charge battery, & make sur u choose correct TP (this happen with me before with wrong TP) |
you f'ed up the flash chip according to the log |
u damaged the flash chip during tp procedure maybe it is loosing contact somewhere use sone flux and hotair , will help u ryaz |
What the hell you say,phone is working properly,i think there is some problem with boot version 6.8.2,because i've done a lot of v3x,and only have problem with 2 pieces. I've restart pc and all things i can do but no way to unlock it. |
Flash microchip could not be detected. Apparently it got damaged during shield removing. Try to put some hot air on PCB, it might improve the connectivity & solve the problem. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
What kind of support is this ,you dont need to move any metal shield in V3x. Please read properly. |
they donīt want to read ur post. V3X not need to remove any shield. do u remove test point before unlocking? usually u have to do it like this for V3X: start program Attach phone to smart clip without battery connect test point attach battery search for phone phone should be detected by program and SWITCHES TO FLASH MODE remove test point do what u want now with ur phone |
sonkar don't listen this bul...i was freeked when i see the support give you such an idea(go on support and take a look of testpoint gsm_support) man recconect your smart clip and try again,again,....for me he works.good luck |
IT LOOKS LIKE SMART-CLIP TEAM PRACTICES ON DIFFERENT V3X THAN US IT IS FUUNY THOUGH CUZ ONE ADVICES TO DOWNGRADE BOOTLOADER ON A V3R TO UNLOCK AND THE OTHER SAYS V3X DAMAGED DURING REMOVING SHIELD http://forum.gsmhosting.com/vbb/show...&highlight=V3R SUPPORT:confused: :confused: :confused: |
OK, we use a standard replays, let's say that chip was damaged during disassembling, not the shield removing. What does it change? Flash chip still can not be detected and still needs to be repaired. Regarding V3r. It could be unlocked via downgrade boot method, as most of the phone models, it just needs done as V3i. There is nothing wrong on that recommendation. Any more suggestions? Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
yes, here's one: why can we not flash v3x's with 6.8.2 bootloader? they unlock ok though. no standard replies please, like before. br |
It requires to be connected with testpoint to be flashed. Direct flashing with *.shx files will be added in future. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
