Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 05-15-2006, 18:23   #1 (permalink)
Member: 2800
Thanks Meter: 47
Motorola V3x not unlocking
I use TP and always get same error,i've done many but having problems with 2 pieces.
Here is log
Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... 3.10
Reading bus width... OK
Reading flash id... 0x0070-0x00B1 (x2)
Phone group: A835,A845,A920,A925
Internal error 0001
Old 05-15-2006, 22:54   #2 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
Here is log
Internal error 0001
restart your pc and repeet unlocking procedure
some times v3x can be a pain
as i can see in your log that it hasn't detected the right group
so keep trying till it says ok
i had a problem on c975 and every time was an error but didn't give up
so got sorted at the end
good luck
br
Old 05-16-2006, 00:07   #3 (permalink)
Registered User
MAGICMOBILE's Avatar
Member: 213203
Thanks Meter: 5
Here is log
Internal error 0001
you must remove tp after searching the phone befor unlock
Old 05-16-2006, 01:25   #4 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
full charge battery, & make sur u choose correct TP (this happen with me before with wrong TP)
Old 05-16-2006, 02:25   #5 (permalink)
Member: 216515
Thanks Meter: 4
you f'ed up the flash chip according to the log
Old 05-16-2006, 04:11   #6 (permalink)
ryaz1993.'s Avatar
Member: 222481
Thanks Meter: 30
u damaged the flash chip during tp procedure
maybe it is loosing contact somewhere
use sone flux and hotair , will help u
ryaz
Old 05-16-2006, 11:25   #7 (permalink)
Member: 2800
Thanks Meter: 47
What the hell you say,phone is working properly,i think there is some problem with boot version 6.8.2,because i've done a lot of v3x,and only have problem with 2 pieces.
I've restart pc and all things i can do but no way to unlock it.
Old 05-16-2006, 14:58   #8 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
Flash microchip could not be detected. Apparently it got damaged
during shield removing. Try to put some hot air on PCB, it might
improve the connectivity & solve the problem.
Best Regards
GSMServer team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 05-16-2006, 18:06   #9 (permalink)
Member: 2800
Thanks Meter: 47
What kind of support is this ,you dont need to move any metal shield in V3x.
Please read properly.
Old 05-16-2006, 19:42   #10 (permalink)
Member: 1246
Thanks Meter: 25
Reply U got Was the UNIVERSAL Answer users get when having problems...
they donīt want to read ur post.
V3X not need to remove any shield.
do u remove test point before unlocking?
usually u have to do it like this for V3X:
start program
Attach phone to smart clip without battery
connect test point
attach battery
search for phone
phone should be detected by program and SWITCHES TO FLASH MODE
remove test point
do what u want now with ur phone
Old 05-16-2006, 19:51   #11 (permalink)
Member: 91963
Thanks Meter: 34
sonkar don't listen this bul...i was freeked when i see the support give you such an idea(go on support and take a look of testpoint gsm_support)
man recconect your smart clip and try again,again,....for me he works.good luck
Old 05-17-2006, 01:02   #12 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
Best Regards
GSMServer team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
IMPRESSIVE
IT LOOKS LIKE SMART-CLIP TEAM PRACTICES ON DIFFERENT V3X THAN US
IT IS FUUNY THOUGH CUZ ONE ADVICES TO DOWNGRADE BOOTLOADER ON A V3R TO UNLOCK AND THE OTHER SAYS V3X DAMAGED DURING REMOVING SHIELD
http://forum.gsmhosting.com/vbb/show...&highlight=V3R
SUPPORT
Old 05-17-2006, 09:02   #13 (permalink)
Member: 121052
Sonork: 100.107126
OK, we use a standard replays, let's say that chip was damaged during disassembling, not the shield removing.
What does it change? Flash chip still can not be detected and still needs to be repaired.
Regarding V3r. It could be unlocked via downgrade boot method, as most of the phone models, it just needs done as V3i. There is nothing wrong on that recommendation.
Any more suggestions?
Best Regards
GSMServer team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
Old 05-17-2006, 09:50   #14 (permalink)
James-R's Avatar
Member: 104911
Thanks Meter: 42
yes, here's one:
why can we not flash v3x's with 6.8.2 bootloader? they unlock ok though.
no standard replies please, like before.
br
Old 05-17-2006, 10:07   #15 (permalink)
Member: 121052
Sonork: 100.107126
It requires to be connected with testpoint to be flashed.
Direct flashing with *.shx files will be added in future.
Best Regards
GSMServer team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
motorola c115 not unlock shabeermobile Infinity-Box 7 08-18-2009 07:54
motorola v3x not power on iliralla Motorola Hardware Repair 2 08-08-2009 18:18
Motorola V3x Free Unlocking Tool Rana Bose Motorola P2k 0 07-10-2007 12:24
Motorola V1075 not unlocked with GOT deska GOT Motorola 4 01-16-2007 19:14
Motorola Clip2 not unlock C350 lypen17 Motorola P2k 3 02-06-2004 20:42
Page generated in 0.31641 seconds with 9 queries
