Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 07-01-2007, 10:24   #1 (permalink)
ebu mohammed-emin's Avatar
Member: 263993
Sonork: 100.1612432
Thanks Meter: 173
need help flashing in pc flash
hi
i have before many time flash motorola phones in pcflash but in the last time evry phone i will flash get this errore message
Searching for phone... found S Blank Rainbow POG, getting test interface... usb error 7 [5]
Writing firmware "R252211_U_85.97.C3P_LP0032.pcf":
Preparing firmware image
Incompatible superfile for Subscriber Unit state.
The superfile selected is for reflash. Please use a rom superfile.
Flash failed
Finished with result 0x3A: Phone[0002]: Incompatible superfile for Subscriber Unit state.
Flash failed
Flash failed
Flash failed
i insatall the smart moto new
and try with difrent files still same
wat i make wrong?
ebu mohammed-emin
Old 07-02-2007, 07:47   #2 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
Looks like you are trying to revive your dead E770 by flashing it with language pack. And that is the mistake.
Old 07-02-2007, 10:06   #3 (permalink)
Member: 263993
Sonork: 100.1612432
Thanks Meter: 173
no phone work well. i will change only languege.
and i try with difrent flash files all so with full flash.
its not only this phones, i try last time with difrent phones all time get this erorre ,
i install new smart moto but problem is same.
Old 07-02-2007, 10:21   #4 (permalink)
midou01's Avatar
Member: 40632
Sonork: 98231
Thanks Meter: 1,658
why you flash the phone with TP if it power on normally m8???
if you want just to flash language with pcflash mode your phone should be powered on or in flash mode,u should have "found S flash"
Old 07-02-2007, 10:58   #5 (permalink)
Member: 263993
Sonork: 100.1612432
Thanks Meter: 173
its a e770
her the log with out testpoint
Searching for phone... found S Flash Rainbow POG, getting test interface... usb error 7 [5]
Loading RAM downloader for Bootloader
Error sending RAM download for bootloader. Device API Error: 0xE0030007 Address: 0x8000000 Command: ADDR
Flash failed
Finished with result 0xE0030007: Phone[0002]: Error sending RAM download for bootloader. Device API Error: 0xE0030007 Address: 0x8000000 Command: ADDR
Writing firmware "R252211_U85.97.C0R_lp0032.shx":
Unable to connect to the Subscriber Unit. Unable to retrieve interface handle
Finished with result 0x27
Flash failed
Error Flash with L7 in PC flash mode dog_baby Smart-Clip 3 04-19-2007 06:24
usb smart L7 flash need is no in support flash files l7 help davor2003 Motorola P2K (USB-Smart) 0 04-07-2006 21:15
V3 error flashing using PC flash @Death Knight Smart-Clip 0 10-05-2005 09:53
Page generated in 0.15809 seconds with 9 queries
