01-29-2007, 20:12 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: ITALY
Member: 192348 Status: Offline Thanks Meter: 6 | Problem with Change Imei on V3r, firstly was A.30, now is A.52 I have a v3r that firstly was A.30 Boot, i have try to change imei with prepare Phone and that to apply patch imei, but on this operation the SmartMoto give me Error A9. When i connect the phone to Smartclip and search it, show this message: Searching for phone... found Motorola Phone (V3r), getting test interface... clip communication failed While if i connect the phone in boot mode, show this message: Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK After i continue to prepare the phone with positive results, but on the path imei the soft give me Error A9 or similar. Then i have try to connect and search the phone with TP,and it's OK. But if i would directly path Imei, the soft give me the message: Phone is not in flash mode. Please enter flash mode before patching the phone. This can be done by pressing 'Enter flash mode' button on 'Flash' tab (for old boots only!). For newer boots, use 'Prepare phone' operation or TestPoint method and i procede with to put the phone in Flash mode with button on flash Tab, continue the apply patch end write imei, but to power up the phone give me an error, and for resolve i must flash it, without change the imei. I have try also to repair pds before apply path, and now the boot is 0A.52, i have try to apply path imei with TP but the phone to power up give me always error. Excuse me for along speech, but now i don't know like resolve this change with boot 0A.52. Can we help me? Thanks |
01-29-2007, 20:52 | #3 (permalink) |
Member: 192348 Status: Offline Thanks Meter: 6 | The problem not is the Boot, because not is a problem the TP, but, i don't undestand like change it without create error in the phone. What is Javvad repair? Thanks |
01-30-2007, 08:19 | #4 (permalink) |
Member: 192348 Status: Offline Thanks Meter: 6 | I have try another V3r but with boot 0A.52, and i don't understand how can i change the imei on these phone. On the first phone can i downgrade to 0A.30 the boot like was initially ? And how procede i to change?? Thanks |
01-30-2007, 08:30 | #5 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Dirdan, to make Restore IMEI the phone should be turned on (not in boot mode), that's why error A9 appears. IMEI section of SmartMoto service software was implemented by developer of this program for repair (original IMEI restore) purposes only! For some models IMEI could be restored simply by connecting the handset to SmartMoto via Smart-Clip as for flashing. Some models require to be flashed with “IMEI repair firmware patch”, only after that IMEI could be restored. In some cases flash chip on phone’s PCB requires to be replaced, to allow user to restore IMEI. However, every user that applies to this option must remember the original IMEI to be able to restore it. In any case if SmartMoto user, during phone repair process, applies IMEI that differs from the original IMEI, which was previously set with the phone, is doing that on his own responsibility. Developer of SmartMoto software does not take any responsibility for any incorrect use of that program. About Clip communication failed, In case of getting an error "Clip communication failed", while detecting the handset, please check the output of Smart-Clip power source. For stable Smart-Clip functions minimum output is 9V & 500mA. Recommended power supply is 12V & 750mA. Some phone models use a data cable for charging. So, as soon as it gets connected to Smart-Clip it starts charging and uses about 500mA, plus Clip requires another 130-150mA. You can try to downgrade boot version on the first handset to 0A.30 using TP method. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-30-2007, 08:43 | #6 (permalink) |
Member: 192348 Status: Offline Thanks Meter: 6 | I use the smartclip adapter of 9v and 500mA, but i have now testet also a pebl U6 for change imei and after the prepare phone, i try to change imei and the result is ERROR A9. And the phone is in boot MEM MAP BLANK, for return it to power up , i have sent a full flsh with RSD. Why this error? the change imei not is ok? |
02-11-2007, 12:14 | #7 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Quote:
Try to write boot 0a.30 via TP and then full flash. Then you can use Prepair procedure and patch phone as usual. | |
02-11-2007, 13:32 | #8 (permalink) |
Product Supporter Join Date: Dec 2001 Location: in my skin Age: 47
Member: 8086 Status: Offline Thanks Meter: 180 | No no no... it's communication problem, instable between clip and phone or clip and PC. Just try to use adapter 12V/1A for powering your clip, but not higher voltage than 12V! And in smartmoto at Smartclip tab "setup port for - compatibility". |
problem after change imei on 1112!!!! | gsm-lord | Universalbox | 1 | 06-13-2007 19:16 |
Problem with change imei on ME75 | haller | S-Gold Based Phones | 3 | 07-16-2006 21:04 |
Help with change IMEI on T68i | unlockmax | Sony Ericsson | 5 | 10-24-2003 09:58 |
problem with change imei on savvy 168AK | lindovsky | Philips | 0 | 07-07-2003 14:32 |
need help with changing IMEI on BE4 v138, please help | pali | Alcatel & TCL Old Models | 0 | 06-13-2002 18:23 |
