04-21-2007, 10:44 | #1 (permalink) |
Freak Poster Join Date: Jul 2005
Member: 162777 Status: Offline Thanks Meter: 1 | Problem flashing V3im, any help please Have tried repair pds and bombs out towards the end saying clip communication failed and here's the logs for when I tried the pds repair and the full flash SmartMoto 2.22 S-Card: ********* Smart-Clip dongle, v 1.17, assigned Smart-Clip: ********* Europe, initializing... OK Clip serial: *********, version: 3.16, initializing... OK Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7v,K1 Hardware IMEI: 359819001****** Security area saved to "PDS for S Blank Neptune LTE2 359819001****** (6).mbk" Login request... OK Writing flash section 2 of 2... 100% (25.7 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... clip communication failed Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7v,K1 Hardware IMEI: 359819001****** Security area saved to "PDS for S Blank Neptune LTE2 359819001****** (7).mbk" [2] retrying block write at 0x3000... clip communication failed Any help guys?? Cheers DD |
04-21-2007, 11:07 | #2 (permalink) |
Member: 162777 Status: Offline Thanks Meter: 1 | Had a look on boot-loader and couldn't see any V3im files. Looked at some earlier threads and downloaded R47a_G_08.D8.35.smf and that's the flash I tried. Original version was R47a_G_08.D8.85R Cheers DD |
04-21-2007, 11:37 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,767 | The version that you require and higher ones are available at www.boot-loader.com >> Prepaid Downloads >> SmartMoto >> pcf or mfw>> V3i In case of getting an error "Clip communication failed", while detecting the handset, please check the output of Smart-Clip power source. For stable Smart-Clip functions minimum output is 9V & 500mA. Recommended power supply is 12V & 750mA. Some phone models use a data cable for charging. So, as soon as it gets connected to Smart-Clip it starts charging and uses about 500mA, plus Clip requires another 130-150mA. Best Regards GSMServer team |
04-21-2007, 11:45 | #4 (permalink) |
Member: 162777 Status: Offline Thanks Meter: 1 | Hi, Thanks for that I'll check that. I've been putting 9v into the clip so that will explain some of the problems. I went to boot loader and only saw V3i files no v3im's with the itunes. Whats the difference between pcf or mfw, does it matter which one I pick? |
04-21-2007, 11:53 | #5 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,767 | *.mfw - are meant to be used when the handset is connected to PC via Smart-Clip. *.pcf – flash file to be used in PC flash mode of SmartMoto program with S-Card connected to PC USB port. No Smart-Clip is required in this case. For more detailed information, please check SmartMoto user's manual. Best Regards GSMServer team |
04-23-2007, 15:13 | #7 (permalink) |
Member: 162777 Status: Offline Thanks Meter: 1 | Hi Again Below is the log for this V3im. Gone through the PDS repair but still won't flash. Tried it with 2 files but bombs out in the same place. Any ideas?? SmartMoto 2.22 S-Card: 42492**** Smart-Clip dongle, v 1.17, assigned Smart-Clip: 73359**** Europe, initializing... OK Clip serial: 73359****, version: 3.16, initializing... OK Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7v,K1 Hardware IMEI: 359819001****** Security area saved to "PDS for S Blank Neptune LTE2 359819001******(8).mbk" Login request... OK Writing flash section 2 of 2... 100% (27.6 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (14.3 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7v,K1 Hardware IMEI: 359819001****** Security area saved to "PDS for S Blank Neptune LTE2 359819001****** (9).mbk" [2] retrying block write at 0xC000... clip communication failed Operation log saved to "C:\Program Files\GsmServer\SmartMoto\SmartMoto log 23-04-2007.txt" Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7v,K1 Hardware IMEI: 359819001****** Security area saved to "PDS for S Blank Neptune LTE2 359819001****** (10).mbk" [2] retrying block write at 0x14000... clip communication failed Operation log saved to "C:\Program Files\GsmServer\SmartMoto\SmartMoto log 23-04-2007b.txt" Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7v,K1 Hardware IMEI: 359819001****** Security area saved to "PDS for S Blank Neptune LTE2 359819001****** (11).mbk" Writing flash section 2 of 2... 1% (63.6 Kb/sec) io timeout Thanks again DD |
Nokia 2610 Strange Problem I'm Confused Any help please????!!!!!!! | Mohamed_Alsayed | Nokia Hardware & Hardware Repair | 1 | 08-11-2008 23:56 |
Any help Please K320i unlock probleme | Mounir | Cruiser Suite | 4 | 05-30-2008 19:38 |
Problem with download files . Any Help Please | e-gsmshop | Universalbox | 6 | 05-22-2008 07:12 |
Problem with N70 . Any help please . | e-gsmshop | MT-BOX | 10 | 07-06-2007 14:58 |
Update problem.. any help please... | Invader | Smart-Clip | 1 | 01-21-2006 12:33 |
