05-09-2006, 12:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | @all The Experts About V3x I Have Got A Big Problem With V3x I Have Unlocked It With Tp After Unlock No Display So Decided To Remove The Resistor And Short Two Pins But Unfortunately When I Removed The Resistor One Of The Contacts Came Of From The Bord Now I Have Only Got One Pin(the Side We Make Tp) But I Have Go No Contact On The Other Side So Is There Any Fix For It Please Need Asap, Preferably With Schematic, Thanks Br |
05-09-2006, 17:53 | #2 (permalink) |
No Life Poster Join Date: Mar 2003 Location: NCK, Logs, Server
Member: 23684 Status: Offline Sonork: 1582723 Thanks Meter: 684 | You must solder resistor (R=47 Om) back , to old place. Find schematic diagramm , and search other PIN for R. Next time be carefully. WBR! |
05-10-2006, 00:00 | #3 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | thanks for your reply m8 but i have only got one contact one side cotact is completely off so basically it has been ripped from pcb so can't put another resistor i have unlocked quite few of them but two of them had display problem one was sorted without any problem but this one had been a pain because of a damaged contact but not gona give up on it br |
09-04-2006, 13:19 | #4 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Everywhere
Member: 249836 Status: Offline Thanks Meter: 18 | Quote:
12-12-2006, 11:47 | #5 (permalink) |
Product Manager Join Date: Feb 2003 Location: Your Exclusive Source
Member: 20645 Status: Offline Sonork: 100.1579175 Thanks Meter: 635 | Any Body Gone Fix It Cos I Have Same Problem After Unlock V3x With Tp Phone Display Not Coming How To Fix It? Regards Gsm Mind |
12-12-2006, 11:56 | #6 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ GSM MIND, For the V3x that have no display. More likely you have damaged a Testpoint resistor, which is responsible for display functions. Check the resistor, it suppose to have 33 Ohm. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
