12-08-2006, 16:52 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: manchester, uk
Member: 177730 Status: Offline Thanks Meter: 11 | V3r flashing problems ..clip comunicatio failed SmartMoto 1.23 Clip serial: 907xxxxxxx, version: 2.26, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST-M30L0R8000B0 Reading flash id/2... OK, none Phone group: V235,V360,V360v,V3i,V3r,L7,L7v Hardware IMEI: 359419007501587 Security area saved to "S Blank Neptune LTE2 35941900750xxxx.pds" Writing section0 done Flash completed! Login request... OK Writing section0 done Writing section1 done Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing section0 done Please write a corresponding Full_flash file to phone to accomplish repair Writing section1 3FC000/1FE0000... 12% 53.5 Kb/sec clip communication failed help needed badly! |
12-08-2006, 16:56 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ dipu, make sure that TP not shorted and that the handset don't have any hardware malfunction. Check the battery, make sure that it fully charged. And try once again. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-08-2006, 16:58 | #3 (permalink) |
Member: 177730 Status: Offline Thanks Meter: 11 | i use external power, no phone was okay but now is dead. Clean the tp area. i tried many times. phone flashing stops at 12%. i thought it was clip, but fine with l7 flashing and others. thank you |
U6 Unlock Problems ---- Clip Communication Failed ---helppppp | PTR999 | Smart-Clip | 3 | 02-26-2008 04:42 |
v3r flashing problem | chankia | Smart-Clip | 8 | 08-22-2007 07:59 |
V3r flashing problem | teerak2uk | Ultima Box Light | 3 | 05-19-2007 12:53 |
V3r, L6, L7v clip communication failed | JC_BY | Smart-Clip | 5 | 01-10-2007 20:43 |
reading flash id..clip communication failed | GuilleB | Smart-Clip | 10 | 11-23-2005 13:47 |
