12-29-2006, 15:06 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Algeria Age: 44
Member: 146736 Status: Offline Thanks Meter: 5 | IS Server Down ? I can't access to Update Zone to Update my smart Clip i Change PC With XP Pro ,XP SP1 and Win 2000 but same Probleme . Help Please Tcom25100 |
12-29-2006, 15:10 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Please make sure that: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. You have reliable Internet connection 3. LPT port settings are set to EPP in BIOS 4. Your LPT cable works properly 5. You use a stable power supply with your clip (use power adapter) 6. Your IE version is not lower than v5.0 7. If you run update under WinXP, log in as Administrator or any other account with administrative rights 8. You should clear cache of your browser and restart the computer. To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SM-tool, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility Windows XP: if you have problems running unsigned ActiveX, please open Tools > Internet Options > Security > Custom Level and change "Download unsigned ActiveX controls" to "Prompt" Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
cannot connect to server - is server down? | hridaya | Cruiser Suite | 6 | 08-03-2007 20:01 |
is server down | filipas | UniMoto | 0 | 01-15-2006 15:02 |
Is Server down? | sjakie | UniMoto | 1 | 11-19-2005 22:48 |
Is server down? | bzpsmachine | TOTAL MultiServer | 3 | 11-28-2004 17:16 |
is server down i cant make no keys | luckyfahad79 | FuriouS II | 7 | 11-03-2004 10:54 |
