01-29-2007, 11:22 | #1 (permalink) |
Registered User Join Date: Nov 2002 Location: USA Age: 43
Member: 17846 Status: Offline Thanks Meter: 4 | Smart Clip update problem SmartClip update software 1.23 Warning: make sure you use power adapter! Looking for clip at 0x278... Clip serial: 273xxxxxx Firmware version: 2.26 login... OK Server firmware version: 3.12 Clip warranty period: 04-Jan-2005 to 03-Jul-2005 (expired) EEPROM test successfull,reporting... OK Checking dongle... failed No any Smart-Clip dongle found. Please connect dongle and try again. Anybody can help here?? |
01-29-2007, 11:26 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Steph, Please make sure that you do everthing correctly. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-29-2007, 12:30 | #5 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | There is nothing to do with power. Your dongle is not detected. Did you connect it properly? Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-29-2007, 12:46 | #6 (permalink) |
Freak Poster Join Date: Mar 2005 Location: 106 M.V HOUSE .Ahmedabad:-4 Age: 45
Member: 124943 Status: Offline Sonork: 100.1573954 Thanks Meter: 19 | i also my one smat clip update with s card then i connect the phone phone serch then error me error whtas problem sir ialso mail to but not proper solution to me |
01-29-2007, 12:49 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ rashmin, what error appears during unlock\flash procedure? Please show log file, don't forget to hide your serial number. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-29-2007, 13:06 | #9 (permalink) | |
Member: 17846 Status: Offline Thanks Meter: 4 | Quote:
THANKS FOR THE FAST AND RELAIBLE SUPPORT... | |
01-29-2007, 16:34 | #10 (permalink) |
Crazy Poster Join Date: Aug 2005 Age: 64
Member: 170987 Status: Offline Thanks Meter: 2 | update problems my scard or smartclip wont update says check internet setting or try later and scard says Can''t connect to server, network error: ''Socket Error # 10061 Connection refused.'' what is wrong i never had any problems before i bought scard now none will update. |
01-29-2007, 18:18 | #11 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: With You In Mind
Member: 300540 Status: Offline Thanks Meter: 103 | Server hardware upgrading ! Quote:
Pls look HERE BR. | |
09-21-2007, 10:35 | #12 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: GSM-FORUM
Member: 575419 Status: Offline Thanks Meter: 459 | BEST SOLUTION FOR NO ANY SMAT-CLIP Dongel Found Quote:
BEST SOLUTION FOR this erorr: NO ANY SMAT-CLIP Dongel Found INSTALL PortTalk FIRST IN PC AND RESTART YOUR PC .NOW READY FOR UPDATE SMAT-CLIP. BEST REGARD A.MADVALI | |
09-21-2007, 10:40 | #13 (permalink) | |
09-25-2007, 14:52 | #14 (permalink) |
Junior Member Join Date: Jun 2006
Member: 293790 Status: Offline Thanks Meter: 0 | update problem SmartClip update software 1.23 Warning: make sure you use power adapter! Clip serial: 819xxxxxx Firmware version: 3.22 login... OK Server firmware version: 3.23 Clip warranty period: 02-Sep-2005 to 01-Mar-2006 (expired) EEPROM test successfull,reporting... OK Checking dongle... OK Smart-Clip dongle found, serial xxxxxxxxxx Checking dongle... OK Smart-Clip dongle found, serial 195xxxxxxx Checking clip... OK Update stage 1 of 2: Stage 1 of 2 OK, EEPROM ready Update stage 2 of 2: prepare... 500000000repare write failed prepare try #2... 200000000repare write failed prepare try #3... 800000000repare write failed prepare try #4... 200000000repare write failed prepare try #5... 2 prepare write failed |
09-25-2007, 15:02 | #15 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ ariel77, Please save log file and send it to support[at]smart-clip.com As soon as it will be received and all required operations will be performed reply will be sent to you. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Smart-clip Update Problem | Naz66 | Smart-Clip | 31 | 05-17-2010 07:18 |
Smart-clip Update Problem | lxa786 | Smart-Clip | 1 | 10-12-2007 07:47 |
smart-clip update problem | touch_111387 | Smart-Clip | 0 | 07-12-2007 10:41 |
Smart-clip update problems! | hyds | Smart-Clip | 5 | 11-30-2005 09:49 |
Smart clip update problem | haider | Smart-Clip | 16 | 01-08-2005 13:25 |
