03-20-2006, 23:38 | #1 (permalink) | ||
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | Smart-Moto failed unlocking A1000. Said "OK" - but it's not unlocked. Quote:
Some questions first: 1. If i was not using repair cable, then it wouldn't be able to find phone? 2. Since it was able to go through succsessfully, that means that testpoint was OK? Or would it say unlocked OK, even when i don't connect testpoint? | ||
03-21-2006, 01:59 | #3 (permalink) | |
Member: 105625 Status: Offline Thanks Meter: 44 | Quote:
But can anyone confirm that this problem should not be related to bad testpoint, or bad cable? (if either of this was bad - it would have failed before unlocking?) | |
03-21-2006, 22:53 | #5 (permalink) | |
Member: 105625 Status: Offline Thanks Meter: 44 | I have now unlocked the phone two more times - still not unlocked. Can someone from Smart-clip team tell me what's wrong? Quote:
03-22-2006, 14:03 | #7 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | check this solution, in some models is working well because i have same problem with v3x/v3i and is working well.......secure_pds_init is part of SW which cannot be removed by smart clip unlocking procedure and need to delete it manualy....... Start MCK 1.38 and look for the file secure_pds_init in the folder -> a/mobile/system/ and delete it this is link for MCK http://www.webalice.it/gandolfo/MCK1.38.zip this is not my solution, and if works for you sey 10x to motox BR |
03-23-2006, 15:51 | #9 (permalink) |
Member: 105625 Status: Offline Thanks Meter: 44 | Ok, so A1000 is not supported on Smart-clip? I'm really disapointed about the smart-clip. Why is it even called clip? All new phones requires Smart-moto and testpoints. If this is the future, you better release a new USB-based device in stead. The LPT connection is REALLY annoying. |
03-24-2006, 02:36 | #12 (permalink) | |
ExTrEmE99: Ok, i'll ask the customer for permission. | |
03-24-2006, 03:15 | #13 (permalink) |
No Life Poster Join Date: Jan 2006 Location: US
Member: 216515 Status: Offline Thanks Meter: 4 | If the phone is locked it will say "Enter Subsidy code" Invalid sim means the sim connector or sim is damaged. I know the sim may not be damaged but it might be the phone a reset may help but not 100% sure. Also if it says "call fail" you may have hardware problems same problem with my personal rokr i unlocked and damaged |
03-24-2006, 17:51 | #15 (permalink) |
Freak Poster Join Date: Feb 2005 Location: on earth
Member: 120740 Status: Offline Thanks Meter: 3 | A1000 unlocking SmartMoto 1.17 Clip serial: x9xxxxx3, version: 2.22, initializing... OK Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 5.F2 Reading bus width... OK Reading flash id... Intel-28F128L18B Phone group: A1000 Hardware IMEI: 3xxxxxxx5975 Security area saved to "S Flash Rainbow POG 35xx11xxxx975 (1).pds" Testpoint unlock not supported for this boot version hi anyone have idea about this A1000_U.2A.35.07P Last edited by gsm3005; 03-24-2006 at 18:08. |
C3050 unlocked whith ust pro but still not unlock!!! | ..::khaled::.. | UST Pro II | 21 | 11-13-2010 11:40 |
Omnia i900 unlock problem, NS say unlocked but it's not | vitia | NSPRO | 11 | 12-10-2009 21:21 |
Problem with simloc from Z300 - was ok but it's not now | grodzid | Sony Ericsson | 0 | 03-09-2007 11:38 |
S400i shows charging but it's not plugged in! | thewizard-oz | Samsung Hardware Repair | 2 | 11-28-2006 17:14 |
