04-06-2007, 19:36 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Kewempe Bombo rd
Member: 245586 Status: Offline Thanks Meter: 18 | Smartclip box Overpowered by 12v Here is the photo of my dead box, part labbeled X is the burnt part... Here is the photo http://www.sendspace.com/file/u0mixk Last edited by CME; 04-06-2007 at 19:48. |
04-07-2008, 16:19 | #5 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Warwick, UK. Age: 58
Member: 102129 Status: Offline Thanks Meter: 3 | I put my on 12V once (normally 9V supply) because Smart Clip said to use 12V. It stop working for about an hour, as if it had over heated. I always leave the power supply set at 9V now. |
04-08-2008, 07:39 | #7 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ -luigi- & Road_Hog, Recommended power supply for the Smart-Clip is 12V 750mA. What power adapter have you used with the Smart-Clip? What value it has? Write a letter to support[at]smart-clip.com with the description of the problem and serial number of the Smart-Clip. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-08-2008, 08:51 | #8 (permalink) |
Freak Poster Join Date: Aug 2004
Member: 78753 Status: Offline Thanks Meter: 35 | I am using 12 volt direct from 75 Ahs battery which is oprating my ups . for 2years and it working very fine. be noted you can get 12 volt from any high amp dc source, dongle will use its require current . but soruce should not me less than 12 volt 750 mA |
04-08-2008, 09:03 | #9 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Please don't power up your Clip from the battery. Use a stable power adapter instead. Best Regards GSMServer team |
04-08-2008, 09:09 | #10 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | hi taking a look at sc schematic a 7805 is suplying 5volts and 78L33 suplying 3.3volts, I think is a good deal use a 9v power supply, no sure how much power can support that 7805 mounted on sc, but 12v for 5v is more than double voltage needed which will turn on hot v.regulator, best regards Invisible |
04-08-2008, 09:30 | #11 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Smart-Clip holds 12V and 750mA normally. There is no danger for it. Just don't keep it powered ON at all time. Disconnect power from it, when it's not in use. Also, if you are afraid of burning your Smart-Clip, you can alternatively power it up from different source: 10V, 1A. Best Regards GSMServer team |
04-08-2008, 09:42 | #12 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
And any solutions for people who have already burnt there smart clips by high power? like can u atleast tell us wht resistance are the three 3 ressistors (ithink)connected in serial right after the power connector insie the clip? as in my case this is burnt and needs to be replaced! WBR ReyTech. | |
04-08-2008, 09:58 | #13 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ ReyTech, Please write a letter to support[at]smart-clip.com In letter explain what problem you have, attach quality photo of the PCB and specify serial number of your Smart-Clip. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Why cant i update my smartclip box? | howell | Smart-Clip | 7 | 06-19-2008 07:51 |
R1 R2 and D2 damaged by 12v | Uvedovle | Smart-Clip | 1 | 01-22-2007 13:26 |
k510, short circuted by 12v! | .:bono:. | Sony Ericsson Hardware Repair | 0 | 01-07-2007 13:26 |
Problem of Smartclip Box | FMC_GSM | Smart-Clip | 2 | 12-15-2006 03:18 |
How to realize Original Smartclip box? | N761 | Smart-Clip | 5 | 05-10-2006 09:36 |
