01-26-2007, 13:53 | #1 (permalink) |
No Life Poster Join Date: Jan 2005
Member: 108504 Status: Offline Thanks Meter: 21 | smartclip update help Please wait. Software loading... Note: in order to run ActiveX client software you must use Internet Explorer Windows XP SP2: if you have problems running unsigned ActiveX, please open Tools > Internet Options > Security > Custom Level and change "Download unsigned ActiveX controls" to "Prompt" i have done what it says about changing Download unsigned ActiveX controls" to "Prompt" but still no luck i am running xp sp2 could someone please help this is a new computer in 1 month ago so i have never updated smartclip ever on this any help would be great cheers |
01-26-2007, 14:01 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ tombox68m You are using Internet Explorer? If yes, have you installed ActiveX? Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-26-2007, 14:35 | #4 (permalink) | |
Member: 229997 Status: Offline Thanks Meter: 636 | @ tombox68, You use Internet Explorer Quote:
In upper part of Internet Explorer pop-up window appears which asks if you want to use ActiveX. Press yes. Then everything will be OK. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
01-26-2007, 15:00 | #5 (permalink) |
Member: 108504 Status: Offline Thanks Meter: 21 | yes have done all that but i donnot get (In upper part of Internet Explorer pop-up window appears which asks if you want to use ActiveX. Press yes. Then everything will be OK.) this does not come up??? i am using IE 7 could that be the problem???? cheers for help |
01-26-2007, 15:10 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ tombox68, Please make sure that: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. You have reliable Internet connection 3. You use a stable power supply with your clip (use power adapter) 4. If you run update under WinXP, log in as Administrator or any other account with administrative rights Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-29-2007, 10:34 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ reaz.com, ActiveX it's the part of Internet Explorer. In Windows XP SP2: if you have problems running unsigned ActiveX, please open Tools > Internet Options > Security > Custom Level and change "Download unsigned ActiveX controls" to "Prompt" Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
help my smartclip update on 4.04 i test cannot connect search info,this is bug?help. | RCB Telecom | Smart-Clip | 3 | 12-21-2009 17:11 |
why not smartclip updates & almita is updated | harisa | Motorola Old Legacy (EMMI) | 1 | 11-06-2006 16:14 |
SmartClip update software plz help me ineed to work | Mr/konsowa | Smart-Clip | 18 | 08-11-2005 10:10 |
smartclip update 1.21 | focus123 | Smart-Clip | 0 | 09-03-2004 18:32 |
Faulty Smartclip Update ??? | REPAIRMAN | Smart-Clip | 11 | 09-01-2004 10:16 |
