01-27-2007, 02:37 | #1 (permalink) |
Freak Poster Join Date: Aug 2005
Member: 169579 Status: Offline Thanks Meter: 10 | Unlock V1050 unsupported -help pls. //start of log SmartMoto 1.23 Clip serial: xxxxxxxxx, version: 2.26, initializing... OK Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 6.31 Sending boot... load error Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Flash completed! Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 3xxxxxxxxxxxxxx Security area saved to "S Blank Rainbow POG 3xxxxxxxxxxxxxxx.pds" Phone initialization... OK "Remove RSA" performed successfully, you may service and unlock the phone as usual Turning phone off... OK Clip serial: xxxxxxxxx, version: 2.26, initializing... OK Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 5.F1 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 3xxxxxxxxxxxxxx Security area saved to "S Flash Rainbow POG 3xxxxxxxxxxxxxx.pds" Testpoint unlock not supported for this boot version //end of log how to unlock this? or when smart-clip support this? |
01-27-2007, 09:32 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ ktele, After Remove RSA have done, you should unlock it via simple "One button" method. Please read manual. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-28-2007, 19:34 | #3 (permalink) | |
Member: 169579 Status: Offline Thanks Meter: 10 | Quote:
if without s-card dongle, still 'one button' method applicable? pls consult! | |
01-30-2007, 21:03 | #5 (permalink) |
Member: 169579 Status: Offline Thanks Meter: 10 | help - after these processes, my LCD display is half colour - left black, right white. this is not normal, how to fix LCD display. note: LCD was ok before, but after flashing, etc..then display distorted. |
03-01-2007, 03:57 | #6 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Everywhere
Member: 249836 Status: Offline Thanks Meter: 18 | Quote:
Any one have any ideas how to resolve this problems | |
03-01-2007, 09:19 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ evolutionmobile, please tell us what boot and firmware version it originally had. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-01-2007, 14:24 | #8 (permalink) | |
03-01-2007, 14:26 | #9 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ evolutionmobile, Please tell us what firmware version the handset originally had. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
W850i unlocking error. need help pls.. | bakhshalvi007 | Universalbox | 5 | 01-22-2007 16:39 |
HWK cant unlock SE V600 - help pls | ktele | HWK | 7 | 08-06-2006 13:44 |
unlock e616v/22 help pls | matyus111 | NEC | 2 | 03-22-2005 15:27 |
