01-29-2007, 16:52 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Serbia
Member: 42332 Status: Offline Thanks Meter: 2 | v235 critical Code: SmartMoto 2.15 S-Card: Smart-Clip dongle, v 1.12, assigned Smart-Clip: Europe, initializing... OK Searching for phone... found Motorola Phone (V235), getting test interface... OK Model V235 Firmware R3512_G_0A.30.6CR Writing firmware "R3512_G_0A.30.6CR_LP0030.pcf": Loading RAM downloader for Bootloader Error sending JUMP command Device API Error: 0xE003003B Command: JUMP Error jumping to RAM Downloader Flash completed! Flash failed Finished with result 0xE003003B: Phone[0000]: Error sending JUMP command Device API Error: 0xE003003B Command: JUMP |
01-29-2007, 17:01 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ gorang, try to Full Flash with *.mfw file. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-29-2007, 21:23 | #3 (permalink) |
Member: 42332 Status: Offline Thanks Meter: 2 | there is no fullflash R3512_G_0A.30.6CR version at bootloader (only R3512_G_0A.30.3ER and R3512_G_0A.30.3FR)... btw, I have found lng flash file in old smartclip format, I've tried to flash but I received io error - then lucky guess, preparing phone and just after that flashing phone with language file, did the trick. Phone is live and with nonbranded R3512_G_0A.30.6CR and with prefer language so my question is: did I make mistake? do I need always to "prepare" phone when I need to flash lng file into this phone? |
04-12-2007, 13:24 | #4 (permalink) |
Freak Poster Join Date: Oct 2003 Location: srilanka
Member: 40975 Status: Offline Thanks Meter: 62 | v235 critical error apear in display and stoped when i do prepare phone to unlock.i tried full flash but failed. plz give the compleate solution asap. thanks digiview |
04-12-2007, 13:30 | #5 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Digiview, Fully charge the battery, run Prepare cycle and flash the handset with original or higher firmware version. If some error will appear, please post log file here. Don't forget to hide your serial number. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
V235 / V190 Schematics | hornycanuck | Motorola Hardware Repair | 3 | 12-05-2008 03:58 |
Critical Error 80 40 ON Moto v235 | elarkangel | Motorola P2k | 2 | 06-13-2007 18:51 |
First in the World V235 unlock | huzsolt | Motorola P2k | 9 | 10-18-2006 18:05 |
need unlock v235 | Sghair_Gsm | Motorola P2k | 1 | 05-03-2006 06:54 |
V235 supported? | Raklm | Smart-Clip | 2 | 04-04-2006 14:03 |
