12-04-2005, 07:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | v3 8.26 after unlock keypads light only... help Searching for phone... no phone found Clip serial: 8760xxxxx, version: 2.18, initializing... OK Searching for phone... no phone found Clip serial: 8760xxxxx, version: 2.18, initializing... OK Searching for phone... found Motorola Phone (V3), getting test interface... OK Model V3 Firmware R374_G_0E.42.09R Reading info OK Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 8.26 Writing flash section 1 of 1... io timeout Clip serial: 8760xxxxx, version: 2.18, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Writing flash section 1 of 1... io timeout Flash completed!Sending boot... failed Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Clip serial: 876xxxxxx, version: 2.18, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Writing flash section 1 of 1... io timeout pls i need help... what must i do???? the phone doesnt power on anymore but only the keypads lights are on... any advice pls??? |
12-23-2005, 01:51 | #5 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Retired Unlocker in DZ
Member: 69987 Status: Offline Thanks Meter: 10 | I've just encountered exactly the same problem. (boot version FF.FF and io timeout with remove RSA). I did remove RSA but with 4.1V power supply (completed successfully ) and phone is working now. Did not need to flash anything. |
12-23-2005, 05:56 | #6 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | @ryumahon Did ur Get into Bootloader....?? If yes Make it Detect with bootloader tom Smartmoto and Just Simply remove RSA if still get Error While DOing this Just post ur LOG ..Then Ill seee what can i DO |
12-23-2005, 11:01 | #7 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Netherlands Age: 69
Member: 16473 Status: Offline Thanks Meter: 13 | I have the same problem after "Repair PDS" I have followed this instruction from helpdesk of Smartclip because I could not unlock this phone. Flashing etc. was no problem. What should I do? Here is my logfile Clip serial: xxxxxxxxx, version: 2.18, initializing... OK Searching for phone... no phone found Searching for phone... found Motorola Phone (V3), getting test interface... OK Model V3 Firmware R374_G_0E.40.79R Reading info OK Switching to flash mode... OK [S Flash Neptune LTE] Reading phone boot version... 7.E0 Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,V3,V330,V53x,V54x,V55x,V62x ,V635,V80 Hardware IMEI: 357397009580233 Security area saved to "Motorola V3 357397009580233 (3).pds" Login request... OK Writing section0 done Writing section1 done Writing section2 done Writing section3 done Restarting phone... OK Searching for phone... found S Flash Neptune LTE Switching to flash mode... OK Current phone does not correspond model selection Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 2.00 Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,V3,V330,V53x,V54x,V55x,V62x ,V635,V80 Hardware IMEI: 357397009580233 Security area saved to "S Blank Neptune LTE 357397009580233.pds" Writing section1 done Flash completed! Warning: file firmware "R374_G_0E.40.79R" does not match phone firmware "Unknown" Resolving section "language" location... OK Writing section0 language done Flash completed! Last edited by GSM_Support; 12-23-2005 at 15:41. |
12-23-2005, 21:05 | #9 (permalink) | |
Member: 16473 Status: Offline Thanks Meter: 13 | Quote:
I get "Searching for phone .......... no phone found" What else do I have to do? @Smart-Clip support I have done exactly what you wrote me, now phone is dead and now you don't reply on my emails anymore. Jeanfleur | |
12-23-2005, 22:35 | #11 (permalink) | |
but how can I put phone in boot mode when it is (almost) dead? BR, Jeanfleur | |
C902 DEAD after flash keypad light only please help me | azad4u | SETool2 | 23 | 08-09-2010 19:06 |
C902 DEAD after flash keypad light only please help me | azad4u | DreamBox | 1 | 01-02-2010 12:18 |
v3 8.26 cannot unlock ???????? | PTR999 | Smart-Clip | 7 | 04-29-2007 13:47 |
drMoto Moto Razr V3 8.26 direct unlock | Salami1_1 | Main Sales Section | 0 | 11-20-2005 19:05 |
