Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 08-10-2007, 07:28   #1 (permalink)
Member: 269885
Thanks Meter: 50
v3i flash problem,urgent help needed
i have v3i i flash it many time but it still at boot mode
boot version is 0A.30
firmware is R479-G-08.B4.34R
it come to for unlocking,it came its current state after unlocking by ultima box,now i flash it wid smart clip but failed,recive the following log
SmartMoto 2.27
S-Card: xxxxxxxxx Smart-Clip dongle, v 1.40, assigned Smart-Clip: xxxxx000x Europe, initializing... OK
Clip serial: xxxxx0006, version: 3.19, initializing... OK
Searching for phone... could not get USB descriptor
Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... 3.00
Reading flash id... ST - M30L0R8000B0
Reading flash id/2... ST - M58LR128FT, OK
Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,K1,Z3
Hardware IMEI: 353623013243540
IMEI OTP status: locked
Security area saved to "PDS for S Blank Neptune LTE2 353623013243540.mbk"
Writing flash section 8 of 8... 100% (67.5 Kb/sec)
Flash completed!
Reading flash id... 0x90 - 0x0090, chip unidentified
Hardware IMEI: 620C6EF20F3D672
Incomplete chip identification, restore & write functions unavailable
wat should i do for this,urgent help needed
Old 08-10-2007, 07:48   #2 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
@ burraq,
"Reading flash id... 0x0090-0x0090". Incomplete chip identification means that flash memory chip is not read properly. There are two main reasons for that:
1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair.
Connection between the chip and the PCB may be improved by the hot air.
2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 08-10-2007, 08:12   #3 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Unlocking would be more safe if SmartClip was used.
K800i UNLOCK PROBLEM URGENT HELP NEEDED.... joebastian SETool2 9 07-22-2008 15:07
u600 unlock problem urgent help needed burraq UST Pro II 3 07-16-2008 20:19
6300 keypad hang problem .. urgent help need mysticalboy2001 Nokia Hardware & Hardware Repair 0 06-14-2008 16:58
CU720 unlocking problem....urgent help needed... harim_1981 VygisToolbox 8 06-05-2008 15:46
v3i flash problem,urgent help needed burraq Motorola P2k 5 08-17-2007 11:39
Page generated in 0.16334 seconds with 9 queries
