06-14-2006, 19:20 | #1 (permalink) |
Junior Member Join Date: Nov 2005
Member: 199726 Status: Offline Thanks Meter: 1 | V3I (iTunes) DEAD :( , Help!!! SmartMoto 1.22 Número de serie del clip: xxxxxxxx, versión: 2.26, Inicializando... OK Buscando el teléfono... Encontrado S Blank Neptune LTE2, Entrando en interfaz de test... Interfaz no encontrada Entrando en modo flash... OK Buscando el teléfono... Encontrado S Blank Neptune LTE2, Entrando en interfaz de test... Interfaz no encontrada Entrando en modo flash... OK Leyendo versión del boot del teléfono... 3.00 Leyendo la id de la flash... 0xFFFF-0xFFFF Grupo de teléfonos: V235,V360,V360v,V3i,V3r,L7,L7v Leyendo OTP... Error B8 Atención: Lectura de OTP fallida Buscando el teléfono... No se encontro el teléfono Unlock for testpoint and after error. RSD flashing error, any solution? Thanks for all. Sorry mi bad english. |
06-15-2006, 05:17 | #2 (permalink) |
Freak Poster Join Date: Dec 2003 Age: 52
Member: 47532 Status: Offline Thanks Meter: 18 | i hv been waiting for a month n still cant solved my v3i r47a ,just transferring 2 songs by bluetooth n its dead so pls GSM SUPPORT pls hurry up with this v3i problems for unlocking n repairing pds |
06-15-2006, 08:36 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ coyote14, Leyendo la id de la flash... 0xFFFF-0xFFFF means that flash memory chip is not read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-16-2006, 19:15 | #4 (permalink) |
Member: 199726 Status: Offline Thanks Meter: 1 | I have new problem: SmartMoto 1.22 Clip serial: xxxxxxxx, version: 2.26, initializing... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.30 Boot prepare... failed and display PHONE CODE SIG ERROR: ITS BAD FLASHING FOR R479_G_08.B4.34R MI PHONE IS V3I ITUNES NEED FLASH R47A_G_08.D8.35R, HOW REMOVE FIRST SOFTWARE. |
06-17-2006, 08:52 | #5 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ coyote14, Update your Smart-Moto and check this link http://forum.gsmhosting.com/vbb/showthread.php?t=306268 Thank You! Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-17-2006, 13:37 | #7 (permalink) |
Freak Poster Join Date: Apr 2005 Location: china Age: 45
Member: 142233 Status: Offline Thanks Meter: 0 | SmartMoto 1.23 Clip serial: ********, version: 2.26, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST-M30L0R8000B0 Reading flash id/2... OK, ST-M58LR128FT Phone group: V235,V360,V360v,V3i,V3r,L7,L7v Hardware IMEI: 359414002548113 Security area saved to "S Blank Neptune LTE2 359414002548113.pds" Login request... OK Writing section0 done Writing section1 done Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing section0 done Please write a corresponding Full_flash file to phone to accomplish repair Writing section0 boot done Writing section1 done Flash completed! |
06-20-2006, 19:09 | #9 (permalink) |
Member: 199726 Status: Offline Thanks Meter: 1 | Hello, i have new problem, not repair psd for this error in TestPoint: SmartMoto 1.23 Número de serie del clip: XXXXXXXX, versión: 2.26, Inicializando... OK Buscando el teléfono... Encontrado S Flash Neptune LTE2, Entrando en interfaz de test... Interfaz no encontrada Entrando en modo flash... OK Leyendo versión del boot del teléfono... A.30 Boot preparado... Fallido I have problen for bad flashing, this V3i is Itunes(R47A_G_08.D8.35R), and bad flashing for client (R479_G_08.B4.34R) how erasing full v3i and flashing latest vercion R47A_G_08.D8.35R. Sorry my bad english, and thanks for all. |
06-26-2006, 13:33 | #12 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Did you select a correct version from SmartMoto list, before performing Repair PDS procedure? That is important. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-19-2007, 16:29 | #14 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ k2k00, please tell us what firmware version the phone originally had? What phone model you have selected in repair PDS list? Also please tell us with what firmware version you have flashed it. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-20-2007, 08:20 | #15 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 57
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Hi I have a same problem. I make a mistake to flash v3i itunes (r47a) with R479 flash ! Boot 0A52 Now I repair PDS (R47A) and flash it with FF R47A.... and the phone is always in flash mode !!! Anybody help me please ?? Many thanks |
N95 silver shortcircuit battery ends and phone dead :( help plz | pakstar | Nokia Hardware & Hardware Repair | 4 | 02-04-2009 14:31 |
Martech dead :( help | ZATARA_ | Martech CLIP / Box / Key | 5 | 05-06-2007 21:47 |
K700i Dead :( Help Please | Aamir_Zia | Cruiser Suite | 8 | 06-20-2005 02:25 |
T68m Dead :( HELP! | josemi21 | Sony Ericsson Hardware Repair | 0 | 12-30-2004 14:50 |
e820 dead after code read ufs :( help :( | trevor | SYSOL Platform | 4 | 09-22-2004 16:31 |
