02-17-2009, 18:27 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 462664 Status: Offline Thanks Meter: 5 | v3re need some help testpoint failed S-Card: 5xxxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: 4xxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxx, version: 4.08, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Reading data..failed Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Reading data..failed Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Reading data..failed Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot version 0x400 is not supported for model 'V3re' Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot version 0x400 is not supported for model 'V3re' Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK this is after i try testpoint was not working keep getting 9B error so i want to get phone back to normal mode |
02-18-2009, 13:05 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | You are dealing with hardware failure. More likely the flash chip got damaged. Best Regards GSMServer team Last edited by GSM_Support; 02-18-2009 at 13:10. |
02-19-2009, 09:38 | #3 (permalink) | |
Freak Poster Join Date: Feb 2005 Age: 52
Member: 114143 Status: Offline Thanks Meter: 55 | need test point ways for v3re Quote:
can u give me test point ways details in my case completely damaged test point track i have schemate diagram but tp no. not mentioned if u tell pin no. of flash IC. I can find ways thx | |
02-23-2009, 17:41 | #4 (permalink) | |
No Life Poster Join Date: May 2002 Location: EGYPT Age: 42
Member: 11571 Status: Offline Thanks Meter: 24 | Quote:
br tata Last edited by GSM_Support; 02-24-2009 at 09:22. | |
02-23-2009, 20:58 | #5 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 712887 Status: Offline Sonork: gokuu2011 Thanks Meter: 349 | Quote:
THIS IS HARD, check the PCB. WAS SAFE TO UNCOVER THE SHIELD.......... | |
need some help,urgent please!!! I need media file for u880c for australia/DU | skymovefast | LG | 0 | 12-05-2008 16:13 |
Hi Guy Need Some Help Here Pls Helps Me | WinD_VteC | Universalbox | 7 | 10-20-2008 04:43 |
I need some help about motorola v3c[Help] | pentagono | Motorola CDMA | 3 | 07-12-2006 16:09 |
Need Some Help With My Nokia 8260 | HHHRated | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-08-2000 06:04 |
