06-03-2006, 02:24 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: CHILE
Member: 196727 Status: Offline Thanks Meter: 419 | v3x boot 6.8.2 error 001 need help please Número de serie del clip: xxxxxxx, versión: 2.25, Inicializando... OK Buscando el teléfono... No se encontro el teléfono Buscando el teléfono... Encontrado S Blank Rainbow POG, Entrando en interfaz de test... Interfaz no encontrada Entrando en modo flash... OK Leyendo versión del boot del teléfono... 3.10 Leyendo ancho del bus... OK Leyendo la id de la flash... 0x0070-0x00B1 (x2) Grupo de teléfonos: A835,A845,A920,A925 Internal error 0001 i cant unlock it please help i try to unlock it by test point as v3x and v3i and nothing thanks in advance NAFG |
06-03-2006, 02:52 | #3 (permalink) | |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Quote:
restart your pc then repeat the unlocking procedure i had a same problem today with V3X that is how i solved br | |
06-03-2006, 05:06 | #5 (permalink) |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | I Don't think it can be repair Now... As u can See the Phone group its Showing "Grupo de teléfonos: A835,A845,A920,A925" 100% Something wrong with Flash Chip/PCB etc... So u can Count it in H/W Not in S/W... BR. |
06-03-2006, 09:02 | #6 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Hello nafg, Leyendo la id de la flash... 0x0070-0x00B1 (x2 means that flash memory chip is not read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the processor may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the pt procedure. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-03-2006, 11:27 | #7 (permalink) |
No Life Poster Join Date: Jun 2005 Location: insane in da mad brain Age: 46
Member: 154522 Status: Offline Thanks Meter: 48 | i dont think the hw broke..... i have same problem too and i think this is new protect from motorola again, this is the new boot loader for this version v3x.because this is new phone from voda .please gsm server solve this problem...regards....... |
06-03-2006, 11:41 | #8 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | Flash chip not supported yet: This is the inscription bga near to TP: M-Systems Flash Disk Pioneers DiskOnChip(r) MCP MS06-D95S08-B3-P JAPAN0607KSD-E41150 And 2º one is: SPANSION 599-50063-A2 0552CVM C CHINA (c)04 SPANSION just wait. |
06-03-2006, 16:35 | #9 (permalink) |
Member: 196727 Status: Offline Thanks Meter: 419 | Well the phone is brand new so is kind a hard that the phone came damaged from the company and i have perform unlock procedure in v3x like 50 times never have a problem before with a v3x but this is the first time i see a v3x with this boot i want to know if this problem could be that the phone is not supported by smart clip cause this boot or this is not possible and the phone have h/w problems thanks NAFG |
06-03-2006, 18:08 | #12 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 50
Member: 104911 Status: Offline Thanks Meter: 42 | hi Quote:
HI, I have a question about the above answers please. No standard answers please. When you say: "1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the processor may be improved by the hot air." is it possible for the flash chip to be damaged but the phone still work fine on the three network? and: When you say: 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the pt procedure. if the tespoint probe (to gnd) is not in the correct place then surely you cannot get to this error because the phone would not be detected. i have a c975 with this internal error 1, but it still works ok on three but will not unlock. i think that i have pressed to hard on the testpoint though-hole and maybe the track is broken. i'm not really to bothered about the phone as i will replace it but i would just like to know what the problem is. i hope you understand the questions. br | |
06-03-2006, 18:53 | #14 (permalink) | |
Member: 104911 Status: Offline Thanks Meter: 42 | Quote:
Yes, sorry for posting on your post, but we have the same problem but on different phones. And have been given the same answer, so i just wanted more info on the error. br | |
how to unlock v3x 0 6 8 2 | hollyann | Smart-Clip | 2 | 08-12-2008 10:02 |
how to unlock motorolla v3x 0.6.8.2 | kaspersk | Ultima Box Light | 4 | 07-19-2008 19:29 |
v3x 0.6.8.2 unlocking successful | mccm | Smart-Clip | 2 | 09-16-2006 08:41 |
I did sumthing bad 2 my v3- need help PLEASE! | jajukhan | Motorola P2k | 1 | 06-05-2006 21:13 |
Tricky V3x Boot 6.8.2 Cant Unlock It | nafg | Smart-Clip | 2 | 05-31-2006 15:42 |
