09-11-2008, 07:29 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: KERALA
Member: 609370 Status: Offline Thanks Meter: 13 | v3x dead-tried flashing-an error-help me so tried flashing via smart clip-an error as below Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 358003005352BD2 WARNING! Your phone may not power on after downgrading firmware version. This phone can be unlocked only via patching. IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 358003005352BD2.mbk" [2735] retrying block erase at 0x10000000... error BB above error message is not via testpoint-set connected to smart clip after press *,#,power on. help me thank u |
09-11-2008, 07:34 | #2 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ zone2, More likely that the phone has hardware malfunction, as the IMEI can not be read properly Quote:
Try to improve the connection between Flash IC and the PCb of the phone with the hot air. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
01-05-2009, 08:20 | #5 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ albyale, Please explain in more details what problem you have. Show us some log files, it would spread some light at your problem. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-05-2009, 21:21 | #6 (permalink) |
Major Poster Join Date: Dec 2006
Member: 418529 Status: Offline Thanks Meter: 3 | this is the log: Provo a connettermi al telefono... Connesso a S Blank Rainbow POG, Ottengo il test dall'interfaccia... Interfaccia non trovata Posiziono il telefono in flash mode... OK Lettura versione BOOT 3.10 Leggo ID Flash... 0x50 - 0091 (x2), Chip non identificato Gruppo telefoni: A835,A845,A920,A925 IMEI Hardware: 358000062923BD6 IMEI OTP status: locked Telefono non corrispondente con il modello selezionato Spengo il telefono... OK Provo a connettermi al telefono... Connesso a S Blank Rainbow POG, Ottengo il test dall'interfaccia... Interfaccia non trovata Posiziono il telefono in flash mode... OK Lettura versione BOOT 3.10 Versione BOOT 0x310 non e' sopportata per il modello 'V3x' Lettura versione BOOT 3.10 Leggo ID Flash... Intel - 28F256L18B (x2) Gruppo telefoni: E770,E1000,E1070,V3x,V975,V1050 IMEI Hardware: 358003002923284 IMEI OTP status: locked Security area memorizzata a "PDS for S Blank Rainbow POG 358003002923284.mbk" [3727] Riprovo a scrivere il blocco 0x10030000... Errore BE [4429] Riprovo a cancellare il blocco 0x10030000... Errore BB [4414] Riprovo a cancellare il blocco 0x10030000... Errore BB |
01-06-2009, 09:09 | #7 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | The particular sector of the flash chip can not be overwritten. More likely it's damaged. It looks like the flash chip has to be replaced. Best Regards GSMServer team |
5230 ntwk lock-tried an error=help me [ Not Supported model ] | zonetrichur | Cyclonebox | 1 | 02-22-2010 15:27 |
9000 tried to unlock via 2.0.1.3-an error-help me | zone2 | BlackBerry (RIM) | 12 | 12-02-2009 04:59 |
e63 tried to unlock -an error-help me | zonetrichur | Cyclonebox | 6 | 10-18-2009 00:50 |
5700 dead-tried to flash-an error -help | zone2 | HWK | 7 | 11-22-2008 12:10 |
V3 Bootloader Screen-did Repair Pds-then Tried Flash -an Error-help | zonetrichur | Smart-Clip | 6 | 10-30-2007 09:07 |
