09-25-2007, 10:10 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Tanzania
Member: 271974 Status: Offline Thanks Meter: 97 | v3x Help to unlock. |
09-25-2007, 10:24 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ manyosa, Try to read phone info. User code should be read by SmartMoto. In other case you can try to perform the following: 1. power on the phone with any SIM 2. when it asks for user code, press MENU button 3. then it will ask for security password, enter 000000 and press OK (000000 - default security password. It might not be accepted, in case it was modified by user) 4. now you should be able to perform a Master reset & Master clear from the menu. If that will not help, than You should Full flash the handset using TP method. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-26-2007, 07:35 | #6 (permalink) |
Member: 271974 Status: Offline Thanks Meter: 97 | In other case you can try to perform the following: 1. power on the phone with any SIM 2. when it asks for user code, press MENU button 3. then it will ask for security password, enter 000000 and press OK (000000 - default security password. It might not be accepted, in case it was modified by user) 4. now you should be able to perform a Master reset & Master clear from the menu. I have tried this also but with simcard when i press menu button nothing happen but i just hear keypad sound only. I just need the help to read the info with smart clip |
09-26-2007, 07:47 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ manyosa, To be able to read phone info the handset has to be powered on(not in boot mode). Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-27-2007, 07:17 | #8 (permalink) |
Member: 271974 Status: Offline Thanks Meter: 97 | I have tried to read code but a get this error Searching for phone....found motorola phone(RAZRv3x),getting test interface....clip communication failed. Help on this..... |
09-27-2007, 07:27 | #9 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ manyosa, Clip Communication failed issue can be found here. Also please make sure that: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. LPT port settings are set to EPP in BIOS 3. Your LPT cable works properly 4. If you are using WinXP, log in as Administrator or any other account with administrative rights To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SmartMoto, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-27-2007, 09:47 | #10 (permalink) |
Member: 271974 Status: Offline Thanks Meter: 97 | I have follow all instructions now i get this error ....getting phone interface.....AT command error ...This error is possible durring phone turning on,you may try search once again. Im using smartmoto v.2.29 and box firmware is v3.21 Help me on this. |
09-27-2007, 09:57 | #11 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ manyosa, First of all update Smart-clip/S-card and SmartMoto to the latest versions and try to read phone info once again. If the won't help, connect the phone via TP and Full Flash it. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-28-2007, 07:33 | #12 (permalink) |
Member: 271974 Status: Offline Thanks Meter: 97 | I have already update smart clip and s card and now im using smartmoto version 2.35 but still i cant read code I shall try to fullflash and post the results. |
v3x ...problem to unlock with SC | kidgsm | Smart-Clip | 1 | 01-24-2006 12:10 |
V3x How To Unlock ? | .:Kuku:. | Smart-Clip | 19 | 01-17-2006 19:10 |
help to unlock c55,i will calculate DCT4 code to him | cale | Phone Unlocking Codes & Maps | 2 | 03-01-2003 16:29 |
to all who need help to unlock | komix | x1x to x45/x50 | 0 | 01-22-2002 20:57 |
