01-23-2007, 16:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 41
Member: 227726 Status: Offline Thanks Meter: 297 | v3x phone lock AT command eror |
01-23-2007, 16:44 | #2 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ masterspargo, AT command error shows that the handset has user or security code. You can try to perform the following: 1. power on the phone with any SIM 2. when it asks for user code, press MENU button 3. then it will ask for security password, enter 000000 and press OK (000000 - default security password. It might not be accepted, in case it was modified by user) 4. now you should be able to perform a Master reset & Master clear from the menu. If that will not help, then You should Full flash the handset using TP method. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by Mr.Tinkertrain; 01-23-2007 at 17:00. |
01-23-2007, 16:59 | #3 (permalink) |
Member: 227726 Status: Offline Thanks Meter: 297 | not going to security code noting happens when press menu button phone still remains on phone it is not going to security code. i have pressed every button but confused plllllllllz help |
01-24-2007, 11:27 | #4 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Connect it with TP, perform full_flash and unlock after that. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
A887 phone lock | Moosani | NSPRO | 5 | 06-29-2010 14:14 |
v3x phone lock ........... | 081372002070 | Ultima Box Light | 2 | 05-03-2007 12:53 |
v3x phone lock AT command eror | masterspargo | Motorola P2k | 2 | 01-24-2007 23:30 |
AT commands for initiate 3G call & send AT commands to GPRS modem from computer need | codec_romania | GSM Programming & Reverse Engineering | 0 | 08-26-2006 07:53 |
V3x AT command error | PhilK | Smart-Clip | 1 | 06-16-2006 09:18 |
