04-17-2007, 08:43 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Bucharest - Romania
Member: 41354 Status: Offline Thanks Meter: 11 | V3xv unlock problem pls help The phone is: Searching for phone... found Motorola Phone (RAZRV3xv), getting test interface... OK Model RAZRV3xv Firmware R252211LD_U_85.97.CDP Boot version is 0.6.8.3 Any ideas how to make this phone work ok? Is there any posibility to solve this problem by flashing the phone? or is a hardware mailfunction? Any ideeas are apreciated. Need some kind of urgent answer. Thanks in advance Best regards |
04-17-2007, 08:51 | #2 (permalink) |
Member: 41354 Status: Offline Thanks Meter: 11 | I did the unlock again via "prepare phone" procedure. All was ok , and during unlock i can see on the LCD , "software upgrade in progres...." so the LCD is ok , unlocking procedure performed ok , but after unlock same problem - no LCD working. I dont know what to do now , it seems to be a software problem. Should i make a fullflash? should i make repair PDS, should i make a complete repair procedure ( i mean write boot , repair PDS and fullflash all at a time )? Any advices are welcome. Best regards |
04-17-2007, 08:57 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ vali.rusu, You can try to make Repair PDS and after that Full Flash the handset with the same or higher firmware version. If the problem is software then those procedure will solve it. If the problem won't be solved, check TP resistor. It suppose to have 33 Ohm. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-17-2007, 09:10 | #4 (permalink) |
Member: 41354 Status: Offline Thanks Meter: 11 | I will try that but 1 more question ( hope that i am not disturbing u too much ) should i make the repair procedure via "prepare" mode or via TP? Thanks for the quick answer |
04-17-2007, 09:14 | #5 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ vali.rusu, To avoid any type of hardware malfunction we recommend to use Prepare cycle. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by Mr.Tinkertrain; 04-17-2007 at 09:25. |
04-17-2007, 09:16 | #6 (permalink) | |
Member: 41354 Status: Offline Thanks Meter: 11 | Quote:
04-17-2007, 09:47 | #7 (permalink) |
Member: 41354 Status: Offline Thanks Meter: 11 | Repair PDS and full flash performed , still same problem , i will try to solve it by changing that resistor. I've flashed the phone with the option "overwrite boot area" NOT checked. Could this be a problem? ( i didnt wrote boot in the phone during PDS repair and fullflash operation just prepared the phone - PDS repair and than full flashed the phone with "turn of the phone after flashing" option checked - all ok ,no errors- i know that this can be an silly question but i dont want to make something wrong again ). Thanks again Also i didnt check the option "unlock automatically after prepare". And something strange: after this operation , if i conect it again to smart moto , when the smartmoto read phone's info it shows that now the Boot version is 6.82 and i didnt wrote any bootfile ( the phone was originally boot 6.83 ) Last edited by vali.rusu; 04-17-2007 at 10:08. |
04-17-2007, 10:58 | #8 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Try flashing it back with boot V3x_boot_6.8.3.mfw. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-17-2007, 12:44 | #9 (permalink) |
Member: 41354 Status: Offline Thanks Meter: 11 | Solved through hardware repair. I had damaged the resistor probably when i made the TP. My fault. Thanks everyone for the great and quick reply. Best regards. |
A55 unlock problem pls help??? | proxy_gsm | E-Gold Based Phones | 20 | 12-12-2003 12:23 |
6310i ver 5.22 unlock problem ... pls help ... | alianu | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 06-17-2003 20:55 |
GD 55 Unlock Problem - PLS Help | Synchro | Panasonic | 0 | 05-14-2003 07:25 |
Geo@i mt345 unlock problems....pls help | PTR999 | Mitsubishi | 0 | 10-14-2002 09:56 |
