02-20-2009, 03:33 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 267265 Status: Offline Thanks Meter: 8 | <<<< v3xx after unlock bootloader >>> heres the logs... SmartMoto 3.20 S-Card: ;;;;;;;; Smart-Clip dongle, v 2.10, assigned Smart-Clip: ;;;;;;;;; Europe, initializing... OK Clip serial: ;;;;;;;;, version: 4.08, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S71WS512NE0 Reading flash id/2... AMD - S71WS512NE0, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 353292012104200 IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 353292012104200.mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_0E03131764C59BD5.bk_ Restore OK Unlocking phone... OK but bootloader only on screen.. then i try to flash.... SmartMoto 3.20 S-Card: xxxxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxx, version: 4.08, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... no phone found Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S71WS512NE0 Reading flash id/2... AMD - S71WS512NE0, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 353292012104200 IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 353292012104200 (2).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Writing flash section 2 of 2... 100% (88.8 Kb/sec) Flash completed! but no luck,then i try again another file untypical... SmartMoto 3.20 S-Card: xxxxxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxxx, version: 4.08, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... no phone found Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S71WS512NE0 Reading flash id/2... AMD - S71WS512NE0, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 353292012104200 IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 353292012104200 (1).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Writing flash section 2 of 2... 100% (90.7 Kb/sec) Flash completed! again no luck.what should i do?please guide me to revive this phone or the correct file for this..thanks p.s i unlock many v3xx before. |
02-20-2009, 03:40 | #2 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Wish i was on Mars Age: 40
Member: 789089 Status: Offline Sonork: 100.1617*** Thanks Meter: 267 | i had the same problem with a v6..how ever as it was stuck in boot loader...i just flashed the phone and thos solved ma problem..u can try it |
02-20-2009, 03:53 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 47
Member: 135671 Status: Offline Thanks Meter: 45 | Yes. I'm have problem with V3xx AT&T. Hope team fix this problem. But i think some time user may be to chose other model then to do not sucess. Thank & best regards |
02-20-2009, 07:03 | #8 (permalink) |
Member: 267265 Status: Offline Thanks Meter: 8 | try again unock but no luck.please help me!! SmartMoto 3.20 S-Card: %%%%%%%%%% Smart-Clip dongle, v 2.10, assigned Smart-Clip: %%%%%%%%%%Europe, initializing... OK Clip serial: %%%%%%%%, version: 4.08, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S71WS512NE0 Reading flash id/2... AMD - S71WS512NE0, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 353292012104200 IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 353292012104200 (6).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Writing flash section 2 of 2... 100% (88.9 Kb/sec) Flash completed! |
02-20-2009, 11:54 | #9 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | What FW version the handset originally had and what FW version did you flash to it. Please flash your phone with the same or higher FW version. If your phone sill in boot mode after the flashing, then it got damaged during testpoint process. ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com Last edited by Mr.Tinkertrain; 02-20-2009 at 11:59. |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
01-12-2010, 09:54 | #12 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ *shohel*, Please explain in more details what problem you have. What problem the set originally had? What procedures did you perform? Best Regards GSMServer team |
V3xx after unlock No service?? | ~mr_Ten$ion~ | Smart-Clip | 16 | 03-16-2017 19:06 |
v3xx untypical cingular after unlock bootloader | lorenzo roberto | Smart-Clip | 3 | 06-24-2009 11:24 |
V3xx after unlock open only bootloader mode | Elias Khan | Smart-Clip | 1 | 01-29-2009 10:32 |
V3xx after unlock still lock. | haider | Smart-Clip | 4 | 11-12-2008 08:20 |
v3xx after unlock no signal help | ahmertelecom | Smart-Clip | 1 | 10-13-2007 10:04 |
