02-23-2009, 07:48 | #1 (permalink) |
Freak Poster Join Date: May 2004
Member: 67367 Status: Offline Thanks Meter: 47 | V3xx boot loader phone upon turning on the phone boot loader will indicate. So i tried to flash same version which is boot loader 03.02, R26111LD-AS_U_96.80.55AR upon flashing the phone when it reaches to 6% an IO error will ocured and on the screen of the phone Critical Error: DEA1. So i tried other versions R26111LD_U_96.66.73BR & R26111LD_U_96.80.53R I still got the same IO error. Can anyone help me with this mates? |
02-23-2009, 10:36 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Please ensure that phone battery is fully charged and you are using a stable (10V, 1A or 12V, 750mA) power supply with your Smart-Clip, then try again. In case of having the error, please post a log file without serials. Best Regards GSMServer team |
02-24-2009, 02:23 | #3 (permalink) |
Member: 67367 Status: Offline Thanks Meter: 47 | Hello sir, I am using this kind if (10V, 1A) power supply with my Smart-Clip, then on my phone i am also using a fully charged battery and i also tried to use Regulated Power Supply set to 3.7V to ensure the stability of the power of the phone still no luck. Here's my logs: SmartMoto 3.20 S-Card: XXXXXXXX Smart-Clip dongle, v 2.10, assigned Smart-Clip: XXXXXXXXX Europe, initializing... OK Smart Adaptor: serial XXXXXXXXXX, firmware version 1.05 Clip serial: XXXXXXXXX, version: 4.08, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 io timeout |
02-24-2009, 04:01 | #4 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | are you triying to flash a .mfw file? If so this file is not intended to be flashed to a normal working phone juts those in S Blank mode or after prepare procedure, try to flash it with a .pcf file. |
02-24-2009, 05:27 | #5 (permalink) | |
Member: 67367 Status: Offline Thanks Meter: 47 | Quote:
V3xx_R26111LD- AS_U_96.80.55AR_lp0055_USIZRGBLHGMOPTUSAUS00117R26 11101E_full_flash.mfw | |
02-24-2009, 09:48 | #6 (permalink) | ||
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Quote:
The thing is that Timeout error appears even before the flash file is located and loaded. Quote:
You can try flashing this handset using SCout flasher. Just i have a suspects, that flash chip can be damaged and flashing will not help. Best Regards GSMServer team | ||
The Following User Says Thank You to GSM_Support For This Useful Post: |
02-28-2009, 07:34 | #7 (permalink) |
Member: 67367 Status: Offline Thanks Meter: 47 | Hello, The phone is done via Scout flasher. Thanks for all who help. Here's the logs: SCout 1.16. Flashing phone "S Flash Argon - R26111LD-AS_U_96.80.55AR" with firmware "E:\Cellshoppe\Motorolla\R26111LD_U_96.66.73BR _LP0 038_UCIZRGBLEMEAR2611105F\R26111LD_U_96.66.73BR_LP 0038_UCIZRGBLEMEAR2611105F.sbf"... Preparing firmware image... Loading RAM downloader for bootloader... Erasing flash memory... Erase completed! Flashing code group 0... Code group 0 flashed Flashing code group 1... Code group 1 flashed Flashing code group 2... Code group 2 flashed Flashing code group 3... Code group 3 flashed Flashing code group 4... Code group 4 flashed Flashing code group 7... Code group 7 flashed Flashing code group 15... Code group 15 flashed Flashing code group 17... Code group 17 flashed Flashing code group 18... Code group 18 flashed Verifying checksums... Code group 0 checksums match Code group 1 checksums match Code group 2 checksums match Code group 3 checksums match Code group 4 checksums match Code group 7 checksums match Code group 15 checksums match Code group 17 checksums match Code group 18 checksums match Phone is being rebooted... Device did not re-enumerate after flash operation.Please manually reconnect the device Flash completed! |
02-28-2009, 10:55 | #8 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Perfect! Glad to know that you succeeded in repairing this phone. Also, i am glad that hardware is in tact, and the handset is "back to life". Best Regards GSMServer team |
v3xx boot loader 03.02 | MAHMOOD | Smart-Clip | 6 | 01-08-2008 10:41 |
V3xx Boot loader mode during unlock | hackerbd | Smart-Clip | 12 | 11-27-2007 23:47 |
V3xx boot loader 4.10 | khoavtran | Smart-Clip | 7 | 10-30-2007 13:30 |
V3xx boot loader only | kaisar | Motorola P2k | 7 | 08-02-2007 08:30 |
razr v3xx boot loader 03.02 unlocking help smart clip team | gsmservices | Smart-Clip | 0 | 01-20-2007 11:07 |
