02-16-2009, 09:00 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | v3xx flash-mode !!! plz help i also try to flash by SCOUT.................................. SmartMoto 3.20 S-Card: xxxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxx Europe, initializing... OK Smart Adaptor: serial xxxxxxxxx, firmware version 1.05 Clip serial: xxxxxxxxxx, version: 4.08, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.10 io timeout please help..................... Last edited by reaz.com; 02-16-2009 at 09:10. |
02-16-2009, 11:50 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | What is you phone's original fw version and what version of flash file have you used for flashing? As can be seen from the log original firmware version of your phone is R261171MRK-AS_U_99.31.08R and you had to use the same or higher version for flashing! And now try to find 10 distinctions between this two versions: R261171MRK-AS_U_99.31.08R and R26117RK_U_98.50.14R So why are you trying to flash the phone with R26117RK_U_98.50.14R firmware version? I advice you to flash this flash file R261171MRK-AS_U_99.31.08R_LP0055_DRM0001_VSTU_207_0C_JPAU_R261171_IZRGLB_AU TEL_ALL_03_USIZRGBLAUTEL850R261171019_1FF_Aust_Tel stra.pcf as most likely your phone is branded to Telstra Australia! Good luck! |
1112 local mode plz help | rahat ali | Nokia Hardware & Hardware Repair | 12 | 07-10-2011 16:18 |
v3xx flash file plz | wael_elmelegy | Motorola P2k | 1 | 12-06-2009 17:59 |
V3r Allways in Boot mode plz help | aleem26 | Motorola P2k | 10 | 10-09-2007 12:59 |
huwai c2205 head set mode plz help | sachin_udai | Various CDMA/TDMA Cell Phones | 0 | 09-28-2007 07:47 |
6681 test mode plz help me | ..::Sunil::.. | Nokia Hardware & Hardware Repair | 1 | 07-19-2007 10:30 |
