02-26-2007, 22:51 | #1 (permalink) |
Major Poster Join Date: Nov 2005 Location: TM Romania Age: 39
Member: 200647 Status: Offline Thanks Meter: 0 | V975 always in flash mode Phone says : Boot Loader : 0.5.F.1 and FirmWare: R245_U82.31.56I. I have tried a repair PDS and full flash with R245_U_82.31.68I and overwrite boot area but the problem persits and the phone diplay's the same thing, like i've done nothing to it. After i made a repair PDS and full flash whitout TP whit the same version like in the phone. Here is the log Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 5.F1 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 355886002890476 Security area saved to "S Flash Rainbow POG 355886002890476 (3).pds" Login request... OK Writing section0 done Writing section1 done Writing section2 done Writing section3 done Restarting phone... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing section1 done Flash completed! Nothing change. I tried again repair PDS with TP but now i get the error Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 355886002890476 Security area saved to "S Blank Rainbow POG 355886002890476 (2).pds" Login request... OK Writing section0 done Writing section1 done Writing section2 done Writing section3 done Restarting phone... OK Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Reading OTP... error B8 Warning: OTP read failed Current phone does not correspond model selection But the model is selected V975.The phone diplay's the same thing like the begining. What can i do more? |
02-27-2007, 08:46 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ calinsuciu, Try to make Repair PDS and after that Full Flash the handset with higher firmware version. Such error Reading flash id... Intel-28F256L18B (x2) appears, when flash chip can not be read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
V975 always in boot mode! | et.com | Smart-Clip | 4 | 05-05-2009 08:59 |
v975 always in flash mode | vbfather | Motorola P2K (USB-Smart) | 8 | 07-29-2006 15:30 |
v551 no power...always in flash mode | dest | Motorola P2k | 6 | 06-21-2006 20:35 |
V220 always in flash mode !!! | GSM SNIPER | Motorola P2k | 3 | 09-15-2005 02:06 |
mss4box always in flash mode | hema | Motorola P2k | 3 | 02-07-2005 13:01 |
