07-16-2008, 04:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ONLY PRIVATE MSG
Member: 220932 Status: Offline Sonork: 100.1592154 Thanks Meter: 110 | v975 unlocking problem LOG SmartMoto 3.14 S-Card: ********Smart-Clip dongle, v 2.08, assigned Smart-Clip: ******** Europe, initializing... OK Clip serial: ********* version: 4.07, initializing... OK Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 6.12 Reading flash id... Micron - MT28F1284W18BET (x2) Phone group: C975,C980,V980 Hardware IMEI: 354910000000005 IMEI OTP status: locked Security area saved to "PDS for S Flash Rainbow POG 3549100000000(1).mbk" Error: file flash data (64 Mb) does not suite phone memory |
07-16-2008, 06:50 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Is everything OK with your handset? Why is it got detected as S Flash Rainbow POG? Can it power ON? Also, are you sure that you are trying to unlock it and do you exactly have v975? Possibly it' a different model?? It looks more likely that you are trying to flash it. Best Regards GSMServer team Last edited by GSM_Support; 07-16-2008 at 07:09. |
07-16-2008, 08:14 | #4 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Connect phone powered on not in flash mode, and press search button so you can view for sure that phone is V975, disconnect and put phone in flash mode (* + # and power on) and look what boot have inside if is 6.12 or 6.31 ok disconnect battery (remember to use charged battery) and power on in normal mode attach to smartclip and search again, now go to tab Unlock and search V975 and press "Remove RSA" and wait procedure complete (attention after erased boot smartMoto ask you to disconnect battery and put back and whit *+# and power on to boot phone in flash mode, you will se on phone Error 1x etc..etc.. np attach to cable and press OK to continue procedure at the End disconnect phone remove battery reset smart clip and attach again to cable now you need only press Button UNLOCK on smartclip and wait unlock process. That's all. |
07-16-2008, 12:54 | #6 (permalink) | |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Quote:
Right.. And what is he suppose to do if the model is not V975? What if the phone is C975 as it's listed in his log file? Best Regards GSMServer team | |
07-16-2008, 12:55 | #7 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | What exactly have you done to solve your problem and do you finally know, what model do you have? Best Regards GSMServer team |
[V975] Unlock problem | patrik.b | Smart-Clip | 11 | 04-06-2010 07:28 |
v975 Unlock Problem.. | LoveLess | Smart-Clip | 2 | 01-18-2010 16:55 |
unlock v975 unlock problem | my_foo | Smart-Clip | 1 | 03-14-2009 12:30 |
motororola v975 unlock problem | damabib | Smart-Clip | 1 | 02-09-2009 20:16 |
V975 unlock problem | Keke | Smart-Clip | 22 | 06-10-2005 20:32 |
