01-27-2005, 09:52 | #1 (permalink) |
Junior Member Join Date: Sep 2003
Member: 38947 Status: Offline Thanks Meter: 0 | NEC 313 Settings After reading the instructions, it worked with my phone (V15) to get the locks away. Now I figured out: 1st: I may use it for makting in- and outgoing calls but: - if I put a U-SIM in, I may select 3 G networks (but non of MY U-SIMs is allowing me to connect to one of the here available networks).... - if I put a non U-SIM in, the maximum I get is a black square in the upper left edge on the screen with 2 or 2,5 in it but NO 3G connection. With a 7600 or an A835 there is no problem to get with these SIMs in a 3G network... 2nd: I am not able to use USSD codes! Calling in possible. 3rd: As I read in the manual, MMS and WAP is only possible in a 3G network, not in 2,5 (GPRS). Are there any solutions - to use a "regular" SIM in the NEC 313 - to use WAP / MMS w/o 3G - to use USSD codes What about the SW? Does it work with an upgrade? How to get it? How to put it in the phone? Thanks for an answer! |
nec 313 unlcok | Nicko_12345 | NEC | 20 | 09-13-2006 10:05 |
Strange Situation in NEC 313 | ediot | NEC | 5 | 12-03-2004 11:09 |
NEC 313 - Displaying your unlock codes | mikemike | NEC | 2 | 07-11-2004 21:20 |
Net unlock code for Nec 313 for UK? | jenniebabieuk | Phone Unlocking Codes & Maps | 2 | 07-05-2004 16:27 |
Nec 313 / 616 | fonetech | Redbox | 1 | 06-04-2004 00:50 |
