Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > NEC
Old 04-28-2013, 05:39   #1 (permalink)
Member: 1687326
Sonork: 100.1646202
Thanks Meter: 60
N-04c NEC MEDIAS Docomo Too Many Patterns Attempts DONE!!! [REFERENCE]
Model
N-04c Nec Medias Docomo
Problem
Too Many Pattern Attempts!
Hard Reset Procedure
Phone Must Be Off
Press Volume Up + Volume Down + Power Switch
Wait Until Download mode appear
Then Press Volume Down
System Recovery will Prompt
Select Wipe Data/Factory Reset
Use Volume Down for Cursor
And Volume Up for Select
Click Yes to delete all user data
"but before to confirm it will need password for recovery"
here's the TIPS:
Take the second digit
 then the last 4 and last 3 and last 2 in the IMEI
 then it is the password for recovery
Screen Shots
enter your 4 digit password will find at the back of phone
it will prompt when your password is correct (just click "YES" to reset)
Finished Product
this 4 digits marked in red must be your password
BR,
The Following 14 Users Say Thank You to Silverstein For This Useful Post:
Old 05-03-2013, 20:40   #2 (permalink)
Member: 1537908
Thanks Meter: 11
Nice information it really work like charm
10000000000000% Tested!
the only mistake is the step after recovery,
it is actually the ''VOLUME UP'' u need to press
b4 u can see the wipe data/factory reset screen,
not the volume down. But he did great.
Best Regard!
The Following 3 Users Say Thank You to solutionpearl For This Useful Post:
Old 06-16-2013, 23:36   #3 (permalink)
Member: 644684
Thanks Meter: 8
Tnx this is a real work 1000000000%
tnx
The Following 2 Users Say Thank You to ali_tofigh For This Useful Post:
Old 09-27-2013, 07:16   #4 (permalink)
Member: 312023
How did you find this out? I have an NEC terrain that has the same requirement for a passcode. I've tried this method and it doesn't work. I know the Medias is made by NEC as well. Appreciate any guidance, thank you.
The Following User Says Thank You to hhsfool For This Useful Post:
Old 12-19-2013, 15:13   #5 (permalink)
Member: 625563
Sonork: Niceguy
Thanks Meter: 40
how can i found password i triyed 1234.123456.11111111.123456789.0000.00000.00000
but no result
what can i do for found my password?
Old 06-03-2015, 14:28   #6 (permalink)
ronygsm123's Avatar
Member: 623873
Thanks Meter: 41
but no result
http://img141.imageshack.us/img141/2316/12152012139.jpg
Old 08-01-2015, 23:33   #7 (permalink)
Member: 2438121
I have the same problem.
I even know my gmail username and password, and entered that, and it still doesn't unlock.
Has anyone managed to recover from too many pattern attempts on the NEC terrain? Thanks.
Old 12-30-2015, 09:52   #8 (permalink)
Member: 758125
the link you gave does not open, is there any other link
The Following User Says Thank You to Leonard bwalya For This Useful Post:
Old 09-03-2016, 20:15   #9 (permalink)
Member: 2347074
Thanks Meter: 30
What you have to do is remove the battery, copy the IMEI somewhere...
Then If your IMEI is:0123456789abcde
Then your recovery Password is:1bcd
The Following 4 Users Say Thank You to dspurs For This Useful Post:
Old 09-03-2016, 20:16   #10 (permalink)
Member: 2347074
Thanks Meter: 30
Old 11-13-2016, 13:23   #11 (permalink)
scorpian1982's Avatar
Member: 2192793
Thanks Meter: 188
thanks dear
it's working.
Old 01-23-2017, 06:58   #12 (permalink)
Member: 2578349
Thanks Meter: 2
Great job thanks
The Following 2 Users Say Thank You to asadkhandanish For This Useful Post:
Old 06-16-2017, 14:07   #13 (permalink)
Member: 2401846
Sonork: 100.1667126
Thanx its work
1bcd
Old 08-14-2017, 09:31   #14 (permalink)
Member: 971642
Sonork: shami_tahir
Thanks Meter: 2
thanks dear
it's working 1000000000000000000%%%%%%%%%
Old 08-16-2017, 14:38   #15 (permalink)
Member: 2347074
Thanks Meter: 30
I have this phone needing network unlock. How do I go about it?
Page generated in 0.20428 seconds with 9 queries
